Community
cancel
Showing results for
Search instead for
Did you mean:
TNaka1
BIOS version 1J2 update error
Please tell me how to update joule's BIOS.
I have the intel joule 570x.The power of joule is running at 12V.
I tried updating the BIOS with reference to "BIOS Update Steps".
https://software.intel.com/en-us/flashing-the-bios-on-joule https://software.intel.com/en-us/flashing-the-bios-on-joule
I downloaded joule-firmware-2017-06-26-1J2-public.zip for BIOS update in Windows8.1.
Intel DnX driver is working.
I failed when I executed flash.bat command.
C:\Users\170004\Downloads\joule-firmware-2017-06-26-1J2-public\DNX>flash.bat Jou
le_C0-X64-Release-1J2-Public_DNX.bin
Intel(R) Flash.bat version # 1.1.15
- Provisioning the eMMC...
- ERROR: Provisioning failed!
- ToLowerTemp:テ・テシ
- Unknown error. See C:\Users\170004\Downloads\joule-firmware-2017-06-26-
1J2-public\DNX\Flash.log for more details.
- Checking for RPMB...
- ERROR: RPMB check failed!
- ToLowerTemp:テ・テシ
- Downloading the BIOS...
Tasuku Nakajima
Community Manager
Hi Tasuku,
Thanks for reaching out.
It seems that you have followed the correct steps to flash the BIOS (https://software.intel.com/en-us/flashing-the-bios-on-joule BIOS Update Steps). However, it is strange that you are getting these error messages. First, I would like to know a little bit more information, have you checked the "Checking your host Environment" section to remove any of the files mentioned there before continuing with the instructions? Did you flash any BIOS before or is this the first time? Which OS does the Joule have? Also, could you attach to your reply the file …\joule-firmware-2017-06-26-1J2-public\DNX\Flash.log?
Moreover, could you please try to flash the BIOS again, but in this case add the "-clear" parameter? The command would be: Flash.bat -clear Joule_C0-X64-Release-1J2-Public_DNX.bin.
-Yermi A.
TNaka1
Dear Yermi.
Thank you for your reply.
I looked at your mail and checked a couple of things.
>>have you checked the "Checking your host Environment" section to remove any of the files mentioned there before continuing with >>the instructions?
⇒ A. Yes, I have. I checked the files mentioned there before continuing with the instructions.
⇒ A. My coworker flashed any BIOS before.
⇒ A. Sorry. I don't know. Maybe the Joule has any of LINUX OS.
⇒ A. I attached to my reply the file Flash.log. Please check the file.
⇒ A. I tryed to flash the BIOS again with "Flash.bat -clear Joule_C0-X64-Release-1J2-Public_DNX.bin", but I got the same error.
C:\Users\ias-user\Desktop\joule-firmware-2017-06-26-1J2-public\DNX>flash.bat
-cl
# 1.1.15
- ToLowerTemp:テ・テシ
- Unknown error.
See C:\Users\ias-user\Desktop\joule-firmware-2017-06-26-
- ToLowerTemp:テ・テシ
- Unknown error.
- Clearing NvStorage...
Best Regards.
Tasuku Nakajima
Community Manager
Thanks for the information provided.
We tested the BIOS 1J2 from the download center, removed any files from "Checking your Host Environment", and re-flashed the board using the -clear parameter. The board booted up fine with no issues.
Could you please flash the board with the previous BIOS 1H3 and let us know if you observe the same behavior? Also, please make sure the board is in DNX boot mode before flashing.
-Yermi A.
Community Manager
Do you have any updates for this case? Could you flash the 1H3 BIOS?
-Yermi
TNaka1
Dear Yermi
Sorry for the late reply.
I have two Joule modules. I flashed two boards with the previous BIOS 1H3 and I observed the same behavior.
Also I made sure the board is in DNX boot mode before flashing.
I can't find a solution.I'm sorry.
Please let me check again next time, because I don't have enough time right now.
Thank you for support.
Best regards.
Tasuku Nakajima
Community Manager
Hi Tasuku Nakajima,
I would like to know if you have any updates. Did you try flashing the BIOS 1H3 again?
-Yermi A
yUsui2
I'm facing same problem.
I tried to update by using the updater and my Joule bricked.
Could you tell me how can I recover?
Yutaka
Flash.bat Joule_C0-X64-Release-1J2-Public_DNX.bin
- ToLowerTemp:テ・テシ
- Unknown error. See C:\Users\yutaka\Downloads\joule-firmware-2017-06-26-1J2-public\DNX\Flash.log for more details.
- ToLowerTemp:テ・テシ
Community Manager
Hello yutakau,
Thank you for contacting Intel Technical Support
Try to flash the 1J2 bios with the '-clear' parameter. On windows I used the following command:
Hope this helps!
Octavian
yUsui2
Hello Octavian,
Thank you for your reply!
I tried flashing with '-clear' parameter. But the situation remains unchanged..
C:\Users\yutaka\Downloads\joule-firmware-2017-06-26-1J2-public\DNX>Flash.bat -clear Joule_C0-X64-Release-1J2-Public_DNX.bin
- ToLowerTemp:テ・テシ
- ToLowerTemp:テ・テシ
Still 'Provisioning failed' error occurs.
Do you have any suggestion?
yutakau
Community Manager
Hello Tasuku,
Did you try flashing the BIOS from another PC as well?
Octavian
