Intel® Makers
9881 Discussions
BLE Service - Location and Navigation, help needed
KSels
New Contributor II
Can anyone help me With the Location and Navigation Service off the BLE?
I want to be able to read UTC Time, Latitude, Longitude, HDOP and VDOP.
Community Manager
Hi KimLorentz,
Thanks for your interest in the Intel Curie platform.
Could you please let me know if you are using the Arduino IDE or the Curie ODK?
I have found an article about using BLE with the Arduino 101* Board, that discusses how to create a BLE Service and communicate with an Android device. In this article also is set up a BLE blood pressure monitoring system to demonstrate the BLE capabilities of the Arduino 101*, therefore, you can take that example as a reference to set up the Localization and Navigation service and the characteristics you need. Please take a look at the article for more details: https://software.intel.com/en-us/articles/arduino-101-bluetooth-low-energy Use Bluetooth® Low Energy Technology with the Arduino 101* Board.
Hope you find this information useful.
-Yermi A.
KSels
New Contributor II
I found out that my tinyTILE Board BLE system is not working. but the BLE on arduino 101 I also have is working.
How do I fix the BLE firmware on the tinyTILE Board? or how to reflash the tinyTILE to be an arduino 101.
Can I use the Curie ODK to install a New bootloader on the Board?
Where do I find the Curie ODK?
Community Manager
The Intel Curie ODK documentation can be found on this site: https://software.intel.com/en-us/node/674972 Intel® Curie™ Open Developer Kit (ODK), it includes three firmware source trees (A, M, and Z). The A tree is the actual Arduino 101 product firmware source code, so you can try to install and use the A tree, additionally, you can try to update the BLE firmware following this instructions: https://software.intel.com/en-us/node/675512 Installing and Using the A Tree.
Regarding the bootloader we recommend you do not modify it, however, in case the bootloader is damaged, you will need to use JTAG to recover it, take a look at this site for more details: https://software.intel.com/en-us/node/675000 About the Bootloader.
-Yermi A.
KSels
New Contributor II
Tnx got it working. The fault was found on the Iphone. I needed to reboot the Bluetooth everytime I changed the code on the intel curie.
Here is my test code for multiple BLE services. still working on the lat/long part but gething closer.
BLEBoolCharacteristic
BLECharCharacteristic
BLEUnsignedCharCharacteristic
BLEShortCharacteristic
BLEUnsignedShortCharacteristic
BLEIntCharacteristic
BLEUnsignedIntCharacteristic
BLELongCharacteristic
BLEUnsignedLongCharacteristic
BLEFloatCharacteristic
BLEDoubleCharacteristic
# include
BLEPeripheral blePeripheral; // BLE Peripheral Device (the board you're programming)
BLEService ledService("19B10000-E8F2-537E-4F6C-D104768A1214"); // BLE LED Service
BLEService batteryService("180F"); // BLE Battery Service
BLEService temperatureService("1809"); // BLE Temperature Service
// BLE LED Switch Characteristic - custom 128-bit UUID, read and writable by central
BLEUnsignedCharCharacteristic switchCharacteristic("19B10001-E8F2-537E-4F6C-D104768A1214", BLERead | BLEWrite);
BLEUnsignedCharCharacteristic batteryLevelChar("2A19", BLERead | BLENotify);
BLEFloatCharacteristic tempChar("2A3C", BLERead | BLENotify);
const int ledPin = 13; // pin to use for the LED
int oldBatteryLevel = 0; // last battery level reading from analog input
float tempLevel = 12.258;
long previousMillis = 0; // last time the battery level was checked, in ms
void setup() {
Serial.begin(9600);
// set LED pin to output mode
pinMode(ledPin, OUTPUT);
// set advertised local name and service UUID:
blePeripheral.setDeviceName("NRH-01");
delay(100);
blePeripheral.setLocalName("NRH-01");
delay(100);
blePeripheral.setAdvertisedServiceUuid(ledService.uuid());
blePeripheral.setAdvertisedServiceUuid(batteryService.uuid());
blePeripheral.setAdvertisedServiceUuid(temperatureService.uuid());
// add service and characteristic:
blePeripheral.addAttribute(ledService);
blePeripheral.addAttribute(switchCharacteristic);
blePeripheral.addAttribute(batteryService);
blePeripheral.addAttribute(batteryLevelChar);
blePeripheral.addAttribute(temperatureService);
blePeripheral.addAttribute(tempChar);
// set the initial value for the characeristic:
switchCharacteristic.setValue(0);
batteryLevelChar.setValue(oldBatteryLevel);
tempChar.setValue(tempLevel);
// begin advertising BLE service:
blePeripheral.begin();
Serial.println("BLE LED Peripheral");
void loop() {
// listen for BLE peripherals to connect:
BLECentral central = blePeripheral.central();
// if a central is connected to peripheral:
if (central) {
Serial.print("Connected to central: ");
// print the central's MAC address:
Serial.println(central.address());
// while the central is still connected to peripheral:
while (central.connected()) {
// if the remote device wrote to the characteristic,
// use the value to control the LED:
if (switchCharacteristic.written()) {
if (switchCharacteristic.value()) { // any value other than 0
Serial.println("LED on");
digitalWrite(ledPin, HIGH); // will turn the LED on
} else { // a 0 value
Serial.println(F("LED off"));
digitalWrite(ledPin, LOW); // will turn the LED off
long currentMillis = millis();
if (currentMillis - previousMillis >= 200) {
previousMillis = currentMillis;
updateBatteryLevel();
// when the central disconnects, print it out:
Serial.print(F("Disconnected from central: "));
void updateBatteryLevel() {
/* Read the current voltage level on the A0 analog input pin.
This is used here to simulate the charge level of a battery.
int battery = analogRead(A0);
int batteryLevel = map(battery, 0, 1023, 0, 100);
if (batteryLevel != oldBatteryLevel) { // if the battery level has changed
Serial.print("Battery Level % is now: "); // print it
Serial.println(batteryLevel);
batteryLevelChar.setValue(batteryLevel); // and update the battery level characteristic
oldBatteryLevel = batteryLevel; // save the level for next comparison
