Trying to detect bme280 sensor with i2cdetect and getting empty scan buffer. So i tried to detect other devices, to check if I have problem with i2c on Edison, and i get address of MPU-6050 and Arduino Uno without any problem, if i scan with i2cdetect. All devices were connected to i2c6, A4/A5 inputs.
Next step - check if bme280 sensor work. So I tried to connect it to Raspberry Pi and Arduino Uno and I get no error there. Bme280 works fine with these two devices.
Any idea why only Edison can not detect bme280?
Hi dimo89,
Have you tried updating the mraa library? According to this thread /thread/80424 https://communities.intel.com/thread/80424, this has been solved by updating the library. There you can find the commands to update it.
echo "src mraa-upm http://iotdk.intel.com/repos/1.5/intelgalactic http://iotdk.intel.com/repos/1.5/intelgalactic"> /etc/opkg/mraa-upm.conf
opkg update
opkg install libmraa0
Pablo
Yes, I tried different versions of mraa and libmraa0 and it did not solve problem
Hi dimo89,
Even if it's very unlikely, there might be a compatibility issue with the sensor, given that some other sensors are recognized on the Edison and that the sensor is recognized in other platforms. However, we can still try some things.
Could you tell me which Edison image you're using?
Also, how are configuring your Edison before attempting to use I2C? Could you please share your configuration?
You can also check this thread to see if the suggestion works for you, /thread/97970 https://communities.intel.com/thread/97970.
Pablo
Right now I use 159.devkit.
I tried
- echo 28 > /sys/class/gpio/export
- echo 27 > /sys/class/gpio/export
- echo mode1 > /sys/kernel/debug/gpio_debug/gpio28/current_pinmux
- echo mode1 > /sys/kernel/debug/gpio_debug/gpio27/current_pinmux
and I get same empty buffer.
Also I tried
- echo 204 > /sys/class/gpio/export
- echo 205 > /sys/class/gpio/export
- echo 236 > /sys/class/gpio/export
- echo 237 > /sys/class/gpio/export
- echo 14 > /sys/class/gpio/export
- echo 165 > /sys/class/gpio/export
- echo 212 > /sys/class/gpio/export
- echo 213 > /sys/class/gpio/export
- if [ ! -d /sys/class/gpio/gpio214 ]; then
- echo 214 > /sys/class/gpio/export
- fi
- echo high > /sys/class/gpio/gpio214/direction
- echo low > /sys/class/gpio/gpio204/direction
- echo low > /sys/class/gpio/gpio205/direction
- echo in > /sys/class/gpio/gpio14/direction
- echo in > /sys/class/gpio/gpio165/direction
- echo low > /sys/class/gpio/gpio236/direction
- echo low > /sys/class/gpio/gpio237/direction
- echo in > /sys/class/gpio/gpio212/direction
- echo in > /sys/class/gpio/gpio213/direction
- echo mode2 > /sys/kernel/debug/gpio_debug/gpio28/current_pinmux
- echo mode2 > /sys/kernel/debug/gpio_debug/gpio27/current_pinmux
Any other ways to configure i2c?
Hi dimo89,
Could you try with the following image http://downloadmirror.intel.com/25028/eng/edison-image-ww25.5-15.zip http://downloadmirror.intel.com/25028/eng/edison-image-ww25.5-15.zip? This is the previous image to the one you're using. Some I2C issues tend to work better in this previous version, I would suggest you to start with that. Also, have you checked the Hardware Guide configuration? If not, you can see it below (there's a little change in relation to the one in the HG that was suggested by a user, you can see it on lines 15 and 16, I would suggest you to try both).
echo 28 > /sys/class/poi/export
echo 27 > /sys/class/poi/export
echo 204 > /sys/class/poi/export
echo 205 > /sys/class/poi/export
echo 236 > /sys/class/poi/export
echo 237 > /sys/class/poi/export
echo 14 > /sys/class/poi/export
echo 165 > /sys/class/poi/export
echo 212 > /sys/class/poi/export
echo 213 > /sys/class/poi/export
echo 214 > /sys/class/poi/export
echo low > /sys/class/poi/gpio214/direction
echo high > /sys/class/poi/gpio204/direction
echo high > /sys/class/poi/gpio205/direction
echo 0 > /sys/class/poi/gpio204/value
echo 0 > /sys/class/poi/gpio205/value
echo in > /sys/class/poi/gpio14/direction
echo in > /sys/class/poi/gpio165/direction
echo low > /sys/class/poi/gpio236/direction
echo low > /sys/class/poi/gpio237/direction
echo in > /sys/class/poi/gpio212/direction
echo in > /sys/class/poi/gpio213/direction
Pablo
Hi dimo89,
Were you able to test our suggestions? Did you have different results?
Pablo
Hi Pablo,
I have finally managed to try 159 image (http://downloadmirror.intel.com/25028/eng/edison-image-ww25.5-15.zip http://downloadmirror.intel.com/25028/eng/edison-image-ww25.5-15.zip)
also configured hardware this way:
echo low > /sys/class/gpio/gpio214/direction
echo high > /sys/class/gpio/gpio204/direction
echo high > /sys/class/gpio/gpio205/direction
echo 0 > /sys/class/gpio/gpio204/direction
echo 0 > /sys/class/gpio/gpio205/direction
and now i2cdetect can find my bme280 sensor.
So problem solved!
Thank you very much for your help!
