Community
cancel
Showing results for
Search instead for
Did you mean:
hp
BSDL file for Quark D2000
Jump to solution
I am looking for BSDL file for quark D2000. Kindly let me know were to get one from.
Thanks & Regards,
Harry
Michelle_C_Intel
Hi Harry,
We are currenltly in the process of producing the BDSL file for D2000 - I will let you know as soon as it is available.
regards,
Michelle.
Michelle_C_Intel
Hi Harry,
regards,
Michelle.
hp
Thanks Michelle,
I am trying to write a code for HTS221 temperature and humidity sensor for Intel Quark 2000 processor using I2C communication.
Could you please provide me the library function or the syntax which I could use to write a code or any similar sensor example.
Please and Thank You,
Harry
Michelle_C_Intel
Hi Harry ,
Have you had a look a the 'accel' and 'magneto' examples provided with the ISSM toolchain ?
These provide examples for the BMC150 Accelerometer/Magnetometer sensor on the D2000 CRB using I2C.
regards,
Michelle.
