Is it correct you can only use these baudrates on the Intel Galileo?
2764800
921600
460800
307200
230400
184320
153600
115200
57600
38400
19200
9600
7200
4800
3600
2400
1800
1200
600
300
Table 98. Baud Rates Achievable with Different DLAB Settings /servlet/JiveServlet/previewBody/21828-102-2-25120/329676_QuarkDatasheet.pdf https://communities.intel.com/servlet/JiveServlet/previewBody/21828-102-2-25120/329676_QuarkDatashee...
Can I achive other baudrates with pyserial?
Hi BrechtW,
The baud rates you listed are achievable in the Quark not necessarily on the Galileo. The Galileo works with a baud rate of 115200. If you wish to use a different baud rate you'd have to create an environment with the configuration you need. Take a look at .
Sergio
I don't mean the serial communication between the Intel Galileo and the PC. Are the baudrates listed the only baudrates you can use on the tx and rx pins (with pyserial)?
I believe those are the only values to which you can set the baud rate. If you look at the document you posted you'll see that the baud rate is equal to
baud rate = (Fbase) / (16 * divisor)
Where Fbase is a constant value and divisor is based on the value of the DLH and DDL registers. The table of the document describes the achievable values with different DLAB settings, which is used to enable reading and writing of DDL and DLH.
Sergio
Did you find our last suggestion helpful? Do you still need assistance with this thread?
Sergio
