Intel® Makers
9881 Discussions
Behavior when booting after power failure, using Windows 10
JD4
I don't have a stick yet, but I'm considering buying it.
I have some question, I hope someone can help.
I need the "stick" to be turn and off automatically when power is connected/disconnected.
I've read on a thread here that is possible by setting the BIOS:
There is a setting called "Power State". It has the choice between "Always ON"...
(source: /thread/78145 https://communities.intel.com/thread/78145 )
So my question is, when booting after power failure -
What is the OS behavior when using Windows 10 -
Does it show any "REPAIR/SAFE mode" menu, etc ?
Is it the same as on standard PC, or it comes with some special settings or recovery that skips all these screens ?
Thanks for your help
Community Manager
Hello John:
If the option on the BIOS for the power state is: "Always On", then after a power failure the stick will boot to windows automatically, you will not get the "repair/safe mode" menu.
Alberto
Community Manager
Hello John:
Alberto
