Community
cancel
Showing results for
Search instead for
Did you mean:
smadd2
Best vision sensor to use with Intel Edison
Jump to solution
Hello
I am new to this and I am trying to implement facial recognition using Intel
Edison for Arduino. Can someone suggest the best Vison Sensor I can buy to implement this?
Pablo_M_Intel
Hi code64,
Using a UVC-compatible webcam (I believe this is what you mean with "vision sensor") and OpenCV should do the job. You can check a list of compatible webcams following this link http://www.ideasonboard.org/uvc/ http://www.ideasonboard.org/uvc/.
OpenCV already have some tutorials on this subject that you might want to check, http://docs.opencv.org/2.4/modules/contrib/doc/facerec/facerec_tutorial.html http://docs.opencv.org/2.4/modules/contrib/doc/facerec/facerec_tutorial.html.
There are also some videos from Intel's Maker Garage, specifically talking about Facial Recognition, you can find them here http://www.intel.com/content/www/us/en/do-it-yourself/garage-content/garage-facial-recognition-video... http://www.intel.com/content/www/us/en/do-it-yourself/garage-content/garage-facial-recognition-video.... There's a lot of information in the Edison Community and around the web that you should check.
PabloM_Intel
Pablo_M_Intel
Hi code64,
PabloM_Intel
