I am unable to run BitBake to build ref-os-iot due to being unable to fetch IcedTea
Examining the log makes it pretty clear that it cannot fetch from a url: http://icedtea.classpath.org/hg/release/icedtea7-forest-2.1/jdk/archive/d7ecb57d3c61.tar.gz http://icedtea.classpath.org/hg/release/icedtea7-forest-2.1/jdk/archive/d7ecb57d3c61.tar.gz When I visit the url in the web browser, it does not exist. Clearly somebody decided to change some settings on their side. The question is: When will the master branch of ref-os-iot be updated to reflect this?
Here is what I thought would be useful from the log:
--2017-06-09 09:29:04-- (try: 2) http://icedtea.wildebeest.org/hg/release/icedtea7-forest-2.1/jdk/archive/d7ecb57d3c61.tar.gz
HTTP request sent, awaiting response... 200 Script output follows
Length: unspecified [application/x-gzip] Saving to: '/home/zachary/ref-os-iot/build/downloads/d7ecb57d3c61.tar.gz'
0K .......... .......... .......... .......... .......... 256K
50K .......... .......... .......... .......... .......... 506K
100K .......... .......... .......... .......... .......... 702K
150K .......... .......... .......... .......... .......... 4.75M
200K .......... .......... .......... .......... .......... 2.10M
250K .......... .......... .......... .......... .......... 761K
300K .......... .......... .......... .......... .......... 4.93M
350K .......... .......... .......... .......... .......... 4.46M
400K .......... .......... .......... .......... .......... 7.50M
450K .......... .......... .......... .......... .......... 3.23M
500K .......... .......... .......... .......... .......... 722K
550K .......... .......... .......... .......... .......... 128M
600K .......... .......... .......... .......... .......... 504M
650K .......... .......... .......... .......... .......... 27.2M
700K .......... .......... .......... . 6.55M=0.6s
2017-06-09 09:29:06 (1.22 MB/s) - Read error at byte 873368 (Success).Giving up.
ERROR: icedtea7-native-2.1.3-r1.0 do_fetch: Fetcher failure for URL: ' http://icedtea.classpath.org/hg/release/icedtea7-forest-2.1/jdk/archive/d7ecb57d3c61.tar.gz;name=jdk...'. Unable to fetch URL from any source.
ERROR: icedtea7-native-2.1.3-r1.0 do_fetch: Function failed: base_do_fetch
ERROR: Logfile of failure stored in: /home/zachary/ref-os-iot/build/tmp-glibc/work/x86_64-linux/icedtea7-native/2.1.3-r1.0/temp/log.do_fetch.22568
ERROR: Task (/home/zachary/ref-os-iot/build/../meta-ref-os-iot/meta-common/meta-java/recipes-core/icedtea/icedtea7-native_2.1.3.bb:do_fetch) failed with exit code '1'
More tinkering shows that when I reset the meta-java submodule, it has a different error ERROR: The following unsupported recipes are required for the build:# | ETA: 0:00:10 cups@core (would be supported in workspacelayer) Each unsupported recipe is identified by the recipe name and the collection in which it occurs and has to be marked as supported (see below) using that format.
Typically each layer has exactly one collection.
Here are the dependency chains (including DEPENDS and RDEPENDS) which include one or more of the unsupported recipes.
-> means "depends on" and * marks unsupported recipes:
full-image -> *cups
full-image -> openjdk-8 -> *cups
full-image -> packagegroup-java-jdk -> *cups
full-image -> packagegroup-java-jdk -> openjdk-8 -> *cups
As many might know, cups commonly refers to C.U.P.S. or Common Unix Printing System. It seems very odd that openjdk-8 would need to have CUPS support. Will Intel be fixing this issue or do I need to file a bug with the meta-java maintainers ?
Hello zalfakir,
Thank you for your interest in the Intel® Joule™ Products.
Could you please tell me which guide you have being following to build the image?
I recently built a full image by following the steps provided in this link: https://github.com/01org/ref-os-iot.
Are you trying to build a custom image?
I'll be waiting for your response.
If you have any update or question, don't hesitate to contact us.
Have a nice day.
Andres V.
Hello zalfakir,
I was wondering if you could check the questions from the last post.
Andres V.
Sorry for the late reply. Turns out it was just an issue with a firewall blocking the icedtea download.
Hello zalfakir,
I'm glad to hear that you could solve the issue.
Thank you for sharing your experience with the community, we really appreciate it.
Have a nice day.
Andres V.
