Intel® Makers
9873 Discussions
'Blink' Example for Microcontroller D2000 Development Platform
Michelle_C_Intel
Below example code will blink the onboard LED on the D2000 Development Platform.
# include "qm_soc_regs.h"
# include "qm_gpio.h"
# include "qm_scss.h"
/* LED on Intel(R) Quark(TM) Microcontroller D2000 Development Platform */
# define LED_BIT 24
# define DELAY 300000UL
# define MAX_LED_BLINKS (10)
static qm_gpio_port_config_t cfg;
int main(void)
uint32_t counter = 0;
QM_PUTS("Starting: Led blink\n");
cfg.direction = BIT(LED_BIT);
qm_gpio_set_config(QM_GPIO_0, &cfg);
while (counter < MAX_LED_BLINKS) {
qm_gpio_set_pin(QM_GPIO_0, LED_BIT);
clk_sys_udelay(DELAY);
qm_gpio_clear_pin(QM_GPIO_0, LED_BIT);
counter++;
QM_PUTS("Finished: Led blink\n");
return 0;
If using ISSM create a project using a template (e.g. hello_word) using the 'Create New QMSI/BSP Project'. Then just paste the above into the main.c .
