Community
cancel
Showing results for
Search instead for
Did you mean:
msoni1
Bluetooth Configuration
Jump to solution
hello, I have done bluetooth communication with Intel edison to my android phone.
But after i power off and again on Intel edison every time i have to configure bluetooth of edion using putty command.
Is there any way to program edison like when i power it on it start searching for available bluetooth and start communicating with the paired device.
I am planning to make stand-aloe device with the help of Intel edison so its not possible everytime to configure it using terminal.
I hope you understand my problem and help me out with this.
Malay Soni
Pedro_M_Intel
Hello Malay_soni,
I was able to automatically connect to my phone (which was previously paired and trusted through bluetoothctl) using the following shell script and then creating a service that starts it automatically:
rfkill unblock bluetooth
sleep 2
bluetoothctl << EOF
connect XX:XX:XX:XX:XX:XX
EOF
sleep 2
I called the script setconnectBT.sh and made it executable with the command:
chmmod +x setconnectBT.sh
Then I created a service called setconblu.service in /lib/systemd/system/ which looked like this:
# !/bin/sh
[Unit]
Description=sets bluetooth and connects the board to a paired device
[Service]
ExecStart=/home/root/setconnectBT.sh
Type=idle
[Install]
WantedBy=basic.target
Then you can enable it with:
systemctl enable setconblu.service
After you reboot your board, it should connect to your phone automatically.
Peter.
Pedro_M_Intel
Hello Malay_soni,
sleep 2
bluetoothctl << EOF
EOF
sleep 2
# !/bin/sh
[Unit]
[Service]
Type=idle
[Install]
Peter.
msoni1
hey .. thank for your help.
But this code is specific for the device address mentioned in the script.
How to configure it so that it automatically detects the available devices and can communicate with the connected device.
Malay Soni
msoni1
I tried this same code.
but it is not working for me.
can you guide me in detail step by step..?
Malay Soni
Pedro_M_Intel
Sorry for the delay in my reply.
I believe you will find what you need in . Take a look at this thread, I think it will help you a lot.
Peter.
msoni1
hey, Peter,
thanks for your help.
But i think in my case the issue is with hciconfig hci0 up & hciconfig hci0 piscan coomand.
I am unable to connect bluetooth with these commannds manually also.
Can you tell me how to configure bluetooth with the help of hciconfig commands.
Malay
msoni1
hey, my code is working now.
Thanks for your help
thanks,
Malay
Pedro_M_Intel
Great to hear Malay. If you ever encounter any other issue, don't hesitate to come back to the community.
Peter.
msoni1
yeah sure...!!
Malay
