Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Bluetooth connecting
Hi everyone. I have a problem with connecting Bluetooth.
I am using intel centrino wireless-N 135. I read a lot of post about bluetooth connecting to iphone 4. but still haven't found solution.
I am getting blocked at input pin code. When i was using and waiting for signal. Iphone4 poped up a message for input pin code I tried 0000,1111,1234..etc..
This is what i typed.
root@clanton~:rfcomm /dev/rfcomm0 1 or 1&.
(i already set up hciconfig hci0 up.)
I don't know where i can set my pin code. I tried sspmode; but not working.
I really need help. thank you and sorry for my bad english.
Highlighted
Re: Bluetooth connecting
This post might give a clue:
http://forums.gentoo.org/viewtopic-t-797762-start-4.html http://forums.gentoo.org/viewtopic-t-797762-start-4.html
In that case, pincodes for specific device pairs are stored in a pincodes file. Maybe there is a way to set a generic PIN there for any device pairs?
Highlighted
Thank you , but actually i tried this already and it didn't work well.. because i think that pincodes file didn't exist at there.And i manually made a hcid.conf file. but don't know how to fit it in to mine.
It is really annoying.. i spent too long time.
Any suggestion for me?
Highlighted
actually pincodes does not help for galileo.
i use 135 ,and follow these commands can connect my iphone yesterday ,but not today(pincode issue i do not know why),
# rfcomm bind /dev/rfcomm0 xx:xx:xx:xx:xx:xx(other bluetooth device mac)
# cat >/dev/rfcomm0
you can try these commands, may you success.
after all of this i prepare to write c programme to communicate with control another bluetooth device like a single chip something on l2 raw data packets.
waiting for some help too.
thank u.
Highlighted
New Contributor II
Just for the record: Distribution specific help pages may not always help, because they often use distribution specific tools. So you should check help pages of other linux distributions too. Also there are different versions of BlueZ in the wild, which behave different (including but not limited to config file and binary locations, and also tools).
To disable the pincode request, you can try:
hciconfig hci0 sspmode 1
SSP = Simple Pairing, doesn't require a pin.
Highlighted
now i can send bluetooth messages from linux to galileo.
  1. follow the steps https://github.com/tokoro10g/galileo-makefile https://github.com/tokoro10g/galileo-makefile, then you can compile c programme without compile
the yoto damn thing or cross compiler.
2. the server run on galileo.(need some of bluez include file bluetooth.h l2cap.h)
server.c
# include
# include
# include
# include
# include
# include
# include
# include
# include
# include
# include
# include
# define RWRR (S_IRUSR|S_IWUSR|S_IRGRP|S_IROTH)
# define BUFFSIZE 1024
void puintobg(){
/* Our process ID and Session ID */
pid_t pid, sid;
/* Fork off the parent process */
pid = fork();
if (pid < 0)
exit(EXIT_FAILURE);
/* If we got a good PID, then
we can exit the parent process. */
if (pid > 0)
exit(EXIT_SUCCESS);
/* Change the file mode mask */
umask(0);
/* Create a new SID for the child process */
sid = setsid();
if (sid < 0)
exit(EXIT_FAILURE);
/* Change the current working directory */
if ((chdir("/")) < 0)
exit(EXIT_FAILURE);
/* Close out the standard file descriptors */
close(STDIN_FILENO);
close(STDOUT_FILENO);
close(STDERR_FILENO);
int main(int argc, char **argv)
puintobg();
time_t timep;
struct sockaddr_l2 loc_addr = { 0 }, rem_addr = { 0 };
struct sockaddr_l2 addr;
socklen_t optlen;
char buf[BUFFSIZE] = { 0 };
char buftmp[BUFFSIZE]={0};
char str[18];
int s, client, bytes_read;
socklen_t opt = sizeof(rem_addr);
// allocate socket
s = socket(AF_BLUETOOTH, SOCK_SEQPACKET, BTPROTO_L2CAP);
// bind socket to port 0x1001 of the first available
// bluetooth adapter
loc_addr.l2_family = AF_BLUETOOTH;
loc_addr.l2_bdaddr = *BDADDR_ANY;
loc_addr.l2_psm = htobs(0x1001);
if (bind(s, (struct sockaddr *)&loc_addr, sizeof(loc_addr)) < 0) {
//perror("Can't bind socket");
goto error;
/* Get local address */
memset(&addr, 0, sizeof(addr));
optlen = sizeof(addr);
if (getsockname(s, (struct sockaddr *) &addr, &optlen) < 0) {
//perror("Can't get local address");
goto error;
ba2str(&addr.l2_bdaddr, str);
//printf("localaddr %s ...\n", str);
// put socket into listening mode
listen(s, 1);
while(1){
// accept one connection
client = accept(s, (struct sockaddr *)&rem_addr, &opt);
ba2str( &rem_addr.l2_bdaddr, buf );
sprintf(buftmp, "accepted connection from %s ", buf);
memset(buf, 0, sizeof(buf));
// read data from the client
bytes_read = read(client, buf, sizeof(buf));
if( bytes_read > 0 ) {
int fd=0;;
//printf("received [%s]\n", buf);
if((fd = open("btContent.log", O_WRONLY | O_CREAT | O_APPEND, RWRR)) < 0)
goto error;
write(fd,buftmp,strlen(buftmp));
write(fd, "[",1);
write(fd, buf, bytes_read);
write(fd, "]",1);
time(&timep);
write(fd,ctime(&timep),24);
write(fd, "\n",1);
//goto error;
close(fd);
close(client);
error:
close(client);
close(s);
exit(1);
3.client.c runs on linux with usb bluetooth device
# include
# include
# include
# include "bluetooth.h"
# include "l2cap.h"
struct sockaddr_l2 addr = { 0 };
int s, status;
char *message;
char dest[18];
if(argc < 2)
fprintf(stderr, "usage: %s \n", argv[0]);
exit(2);
if(argc==3){
strncpy(dest, argv[1], 18);
message=argv[2];
else{
strncpy(dest,"00:15:00:96:7F:93",18);
message=argv[1];
// allocate a socket
// set the connection parameters (who to connect to)
str2ba( dest, &addr.l2_bdaddr );
// connect to server
status = connect(s, (struct sockaddr *)&addr, sizeof(addr));
// send a message
if( status == 0 ) {
status = write(s, message, strlen(message));
if( status < 0 ) perror("uh oh");
close(s);
4.of course do not forget run :
hciconfig hci0 up
hciconfig hci0 piscan
on galileo.
