I have to build an Android app using Android Studio that communicate with Edison through Bluetooth. I'm using SPP Verification with RFCOMM and I want to connect Android app to /dev/rfcomm0. My question is which UUID should I use. My android code is simple:
BluetoothAdapter ba = BluetoothAdapter.getDefaultAdapter();
BluetoothDevice device = ba.getRemoteDevice(mac_address);
UUID uuid = UUID.fromString("8ce255c0-200a-11e0-ac64-0800200c9a66");
BluetoothSocket socket = device.createRfcommSocketToServiceRecord(uuid);
socket.connect();
Is it possible to do this that way?
Hello michalt38,
Thanks for reaching out!
You will have to post your Android specific questions in their community ( https://source.android.com/source/community) in order to get more accurate responses.
However, what I can tell you is how to check your Edison's UUID, enter the following commands:
rfkill unblock bluetooth
bluetoothctl
[You will see an entry called controller in the bluetoothctl interface, copy the MAC address of that device]
show XX:XX:XX:XX:XX:XX
[Use the MAC address of the device called controller, the output of the command above will throw info of that device, including the UUID]
Anyway, I found a very interesting link that I think might be of help for you:
https://stackoverflow.com/questions/4632524/how-to-find-the-uuid-of-serial-port-bluetooth-device
It is about how to get the UUID of a device when it is unknown. I believe it is very suited for your question as it is of Android development and trying to connect through SPP.
I hope this information helps you,
Pedro M.
Hello michalt38,
bluetoothctl
Pedro M.
