Intel® Makers
9880 Discussions
Bluetooth not working with Intel Edison image.
PSuta
I have downloaded "iot-devkit-prof-dev-image-edison-20160606.zip" file and ran "flashall.sh" and booted edison board with latest image.
But hcitool scan gives "Device is not available: No such device"
How can to make bluetooth working ?
FerryT
Valued Contributor I
You didn't read the link above right? Don't use bluetooth_attach. Use `systemctl start bluetooth`.
The bluetooth device is attached automatically because it is in an ACPI table. Other internal workings in kernel I don't know.
You can also use `connmanctl enable bluetooth` to unblock the bluetooth.
I never tried meta-toolchain. I run `make sdk`, see here: https://htot.github.io/meta-intel-edison/3-Building-the-SDK.html
(tested with sumo, not yet tested with thud)
FerryT
A lot of water went under the bridge since these images were created. You might want to try an image based on Yocto Sumo and 4.18 kernel?
Here: https://github.com/edison-fw/meta-intel-edison
Instructions: https://edison-fw.github.io/meta-intel-edison/
Or if you are adventurous: Yocto Thud, 4.20 kernel: https://github.com/htot/meta-intel-edison
Instructions: https://htot.github.io/meta-intel-edison/
PSuta
I am using ubuntu 18
Linux prityaa 4.15.0-42-generic #45-Ubuntu SMP Thu Nov 15 19:32:57 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
I am trying with Yocto Thud, but I am facing some issues in following link given above.
Log files is attached.
PSuta
posted a file with error.
PSuta
Log file with steps executed.
FerryT
@PSuta​ Yes I'm sorry I forgot to commit one commit (layer compatibility) in meta-acpi. If you run `make setup` once more it will pull meta-acpi and then it should work.
PSuta
I appreciate you for your quick and valuable response but I have some doubts.
1 . Error in edison-image
prityaa@prityaa:~/documents/workspace/boards/intel/edison/tools/yocto/my_Edison_Workspace/out/linux64$
$ bitbake -k edison-image
Loading cache: 100% |##################################################################################################################| Time: 0:00:00
Loaded 1263 entries from dependency cache.
ERROR: Nothing PROVIDES 'edison-image'
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION          = "1.40.0"
BUILD_SYS           = "x86_64-linux"
NATIVELSBSTRING     = "universal"
TARGET_SYS          = "i586-poky-linux"
MACHINE             = "qemux86"
DISTRO              = "poky"
DISTRO_VERSION      = "2.6.1"
TUNE_FEATURES       = "m32 i586"
TARGET_FPU          = ""
meta
meta-poky
meta-yocto-bsp      = "thud:1cab405d88149fd63322a867c6adb4a80ba68db3"
NOTE: Tasks Summary: Attempted 0 tasks of which 0 didn't need to be rerun and all succeeded.
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
2 . which branch should i consider for Bluetooth. (primary intentions are to work with Bluetooh)
prityaa@prityaa:~/documents/workspace/boards/intel/edison/tools/yocto/my_Edison_Workspace/meta-intel-edison$
$ git branch --all
* master
 remotes/origin/HEAD -> origin/master
 remotes/origin/dizzy-latest
 remotes/origin/dizzy-multimedia
 remotes/origin/dizzy-rt
 remotes/origin/dizzy-uptodate
 remotes/origin/master
 remotes/origin/morty
 remotes/origin/morty-64
 remotes/origin/original
 remotes/origin/pyro64
 remotes/origin/pyro64-acpi
 remotes/origin/rocko32
 remotes/origin/rocko64-acpi
 remotes/origin/sumo32
 remotes/origin/sumo64
 remotes/origin/sumo64-acpi
 remotes/origin/thud
3 . If I would like to compile customized Linux kernel
how can I do ?
FerryT
  1. Yes, something is wrong. You can see under Machine you have qemu86,not edison, and the active layers are meta, meta-poky, meta-yocto-bsp, none of meta-intel-edison. Something went wrong with make setup. Maybe it's best to do make clean, then make setup, then make image from your ~/documents/workspace/boards/intel/edison/tools/yocto/my_Edison_Workspace directory.
  2. Don't use sumo64, I'm going to remove that one soon. I tested bluetooth on master/thud and on sumo32/sumo64-acpi. In your case I think it is best to use an acpi enabled version, so either master/thud/sumo64-acpi.
  3. You add a patch or a 'kernel fragment' to the recipe linux-yocto like here: https://github.com/edison-fw/meta-intel-edison/blob/sumo64-acpi/meta-intel-edison-bsp/recipes-kernel.... You can see I'm pulling an already customized kernel from andy-shev then adding some 'cfg' which are in the files directory and turn on/off certain kernel configuration flags. You can also add file names ending on .patch from the files directory.
PSuta
I have made changes in working project
1 . checked out new branch, bluetooth_study, from origin/thud
2 . changed edison.conf fille
$ git diff meta-intel-edison-bsp/conf/machine/edison.conf
diff --git a/meta-intel-edison-bsp/conf/machine/edison.conf b/meta-intel-edison-bsp/conf/machine/edison.conf
index 335ae49..60a40c8 100644
--- a/meta-intel-edison-bsp/conf/machine/edison.conf
+++ b/meta-intel-edison-bsp/conf/machine/edison.conf
@@ -7,6 +7,7 @@
 include conf/machine/include/tune-corei7.inc
 TUNE_CCARGS .= " -mstackrealign"
 #DEFAULTTUNE = "corei7-32"
+#DEFAULTTUNE = "corei2-64"
 MACHINE_FEATURES = "bluetooth alsa pci serial usbgadget usbhost wifi x86 ext3"
 KERNEL_IMAGETYPE = "bzImage"
@@ -29,4 +30,6 @@ KCONFIG_MODE="--alldefconfig"
 #KERNEL_MODULE_PROBECONF += "g_multi"
 ACPI_TABLES ?= "arduino.asl spidev.asl"
-ACPI_FEATURES ?= "uart_2w i2c"
+#ACPI_FEATURES ?= "uart_2w i2c"
+ACPI_FEATURES ?= "uart_2w i2c spi"
But I am facing and issue in building linux kernel.
and Log is
prityaa@prityaa:~/documents/workspace/boards/intel/edison/tools/yocto/my_Edison_Workspace/out/linux64/build$
Loading cache: 100% |##################################################################################################################| Time: 0:00:03
Loaded 3084 entries from dependency cache.
Parsing recipes: 100% |################################################################################################################| Time: 0:00:14
Parsing of 2130 .bb files complete (2129 cached, 1 parsed). 3085 targets, 289 skipped, 0 masked, 0 errors.
TARGET_SYS          = "x86_64-poky-linux"
MACHINE             = "edison"
DISTRO              = "poky-edison"
TUNE_FEATURES       = "m64 corei7"
TARGET_FPU          = ""
meta
meta-poky
meta-oe
meta-python
meta-networking     = "thud:6094ae18c8a35e5cc9998ac39869390d7f3bb1e2"
meta-intel          = "thud:15705474477b091a636f4b32a8760f3ac65b1a6e"
meta-intel-edison-distro = "bluetooth_study:f9b3c0c6cb0de2d08b7cd6c1d596674b651b48d4"
meta-acpi           = "eds-4.20:91a31127c4059b70af9d09b79a821a18caba5b76"
Initialising tasks: 100% |#############################################################################################################| Time: 0:00:11
Sstate summary: Wanted 1061 Found 0 Missed 1061 Current 486 (0% match, 31% complete)
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: linux-yocto-4.20.0-r0 do_configure: Function failed: do_configure (log file is located at /home/prityaa/documents/workspace/boards/intel/edison/tools/yocto/my_Edison_Workspace/out/linux64/build/tmp/work/edison-poky-linux/linux-yocto/4.20.0-r0/temp/log.do_configure.29133)
ERROR: Logfile of failure stored in: /home/prityaa/documents/workspace/boards/intel/edison/tools/yocto/my_Edison_Workspace/out/linux64/build/tmp/work/edison-poky-linux/linux-yocto/4.20.0-r0/temp/log.do_configure.29133
Log data follows:
| DEBUG: Executing python function check_oldest_kernel
| DEBUG: Python function check_oldest_kernel finished
| DEBUG: Executing shell function do_configure
| NOTE: make HOSTCC=gcc -isystem/home/prityaa/documents/workspace/boards/intel/edison/tools/yocto/my_Edison_Workspace/out/linux64/build/tmp/work/edison-poky-linux/linux-yocto/4.20.0-r0/recipe-sysroot-native/usr/include -O2 -pipe -L/home/prityaa/documents/workspace/boards/intel/edison/tools/yocto/my_Edison_Workspace/out/linux64/build/tmp/work/edison-poky-linux/linux-yocto/4.20.0-r0/recipe-sysroot-native/usr/lib -L/home/prityaa/documents/workspace/boards/intel/edison/tools/yocto/my_Edison_Workspace/out/linux64/build/tmp/work/edison-poky-linux/linux-yocto/4.20.0-r0/recipe-sysroot-native/lib -Wl,-rpath-link,/home/prityaa/documents/workspace/boards/intel/edison/tools/yocto/my_Edison_Workspace/out/linux64/build/tmp/work/edison-poky-linux/linux-yocto/4.20.0-r0/recipe-sysroot-native/usr/lib -Wl,-rpath-link,/home/prityaa/documents/workspace/boards/intel/edison/tools/yocto/my_Edison_Workspace/out/linux64/build/tmp/work/edison-poky-linux/linux-yocto/4.20.0-r0/recipe-sysroot-native/lib -Wl,-rpath,/home/prityaa/documents/workspace/boards/intel/edison/tools/yocto/my_Edison_Workspace/out/linux64/build/tmp/work/edison-poky-linux/linux-yocto/4.20.0-r0/recipe-sysroot-native/usr/lib -Wl,-rpath,/home/prityaa/documents/workspace/boards/intel/edison/tools/yocto/my_Edison_Workspace/out/linux64/build/tmp/work/edison-poky-linux/linux-yocto/4.20.0-r0/recipe-sysroot-native/lib -Wl,-O1 -Wl,--allow-shlib-undefined -Wl,--dynamic-linker=/home/prityaa/documents/workspace/boards/intel/edison/tools/yocto/my_Edison_Workspace/out/linux64/build/tmp/sysroots-uninative/x86_64-linux/lib/ld-linux-x86-64.so.2 HOSTCPP=gcc -E -C /home/prityaa/documents/workspace/boards/intel/edison/tools/yocto/my_Edison_Workspace/out/linux64/build/tmp/work-shared/edison/kernel-source CC=x86_64-poky-linux-gcc -fuse-ld=bfd -fdebug-prefix-map=/home/prityaa/documents/workspace/boards/intel/edison/tools/yocto/my_Edison_Workspace/out/linux64/build/tmp/work/edison-poky-linux/linux-yocto/4.20.0-r0=/usr/src/debug/linux-yocto/4.20.0-r0 -fdebug-prefix-map=/home/prityaa/documents/workspace/boards/intel/edison/tools/yocto/my_Edison_Workspace/out/linux64/build/tmp/work/edison-poky-linux/linux-yocto/4.20.0-r0/recipe-sysroot= -fdebug-prefix-map=/home/prityaa/documents/workspace/boards/intel/edison/tools/yocto/my_Edison_Workspace/out/linux64/build/tmp/work/edison-poky-linux/linux-yocto/4.20.0-r0/recipe-sysroot-native= -fdebug-prefix-map=/home/prityaa/documents/workspace/boards/intel/edison/tools/yocto/my_Edison_Workspace/out/linux64/build/tmp/work-shared/edison/kernel-source=/usr/src/kernel O=/home/prityaa/documents/workspace/boards/intel/edison/tools/yocto/my_Edison_Workspace/out/linux64/build/tmp/work/edison-poky-linux/linux-yocto/4.20.0-r0/linux-edison-standard-build oldnoconfig
| make: Entering directory '/home/prityaa/documents/workspace/boards/intel/edison/tools/yocto/my_Edison_Workspace/out/linux64/build/tmp/work-shared/edison/kernel-source'
| make[1]: Entering directory '/home/prityaa/documents/workspace/boards/intel/edison/tools/yocto/my_Edison_Workspace/out/linux64/build/tmp/work/edison-poky-linux/linux-yocto/4.20.0-r0/linux-edison-standard-build'
|  GEN    Makefile
| make[2]: *** No rule to make target 'oldnoconfig'. Stop.
| /home/prityaa/documents/workspace/boards/intel/edison/tools/yocto/my_Edison_Workspace/out/linux64/build/tmp/work-shared/edison/kernel-source/Makefile:544: recipe for target 'oldnoconfig' failed
| make[1]: *** [oldnoconfig] Error 2
| make[1]: Leaving directory '/home/prityaa/documents/workspace/boards/intel/edison/tools/yocto/my_Edison_Workspace/out/linux64/build/tmp/work/edison-poky-linux/linux-yocto/4.20.0-r0/linux-edison-standard-build'
| Makefile:152: recipe for target 'sub-make' failed
| make: *** [sub-make] Error 2
| make: Leaving directory '/home/prityaa/documents/workspace/boards/intel/edison/tools/yocto/my_Edison_Workspace/out/linux64/build/tmp/work-shared/edison/kernel-source'
| WARNING: exit code 2 from a shell command.
| ERROR: Function failed: do_configure (log file is located at /home/prityaa/documents/workspace/boards/intel/edison/tools/yocto/my_Edison_Workspace/out/linux64/build/tmp/work/edison-poky-linux/linux-yocto/4.20.0-r0/temp/log.do_configure.29133)
ERROR: Task (/home/prityaa/documents/workspace/boards/intel/edison/tools/yocto/my_Edison_Workspace/meta-intel-edison/meta-intel-edison-bsp/recipes-kernel/linux/linux-yocto_4.20.0.bb:do_configure) failed with exit code '1'
Am I missing any configuration or setting for build system. ?
FerryT
No, it looks like you are missing this patch: https://github.com/htot/meta-intel-edison/commit/113e55597b20700a91697b9c63ff4f0241834b71
Or for some reason it didn't apply.
What it should do: when running setup it should apply a patch to ...meta/classes/kernel.bbclass and replace oldnoconfig by olddefconfig. You can do that manually of course.
That's why you are getting No rule to make target 'oldnoconfig'. Something changed in the kernel makefile and yocto is not yet up to date.
Maybe you need to reset --hard to https://github.com/htot/meta-intel-edison? Nope, you are on f9b3c0c6c which is correct. I am going to try a fresh rebuild tomorrow to see if I can reproduce this.
FerryT
I can reproduce. What happened is this: when switching to thud the mentioned patch did not apply, so I removed it, hoping it would not be needed anymore. But it was, so I applied the fix mentioned above manually. But forgot to add the patch again. Sorry for that, but thanks for reporting. I will fix that tomorrow. I have just force pushed a fix to master and thud.
PSuta
Thanks for all help.
I followed
1 . make edison-image
2 . make flash
3 . reboot
Now I am able to build images but detect BT hci controller.
I tried literally all steps to turn on hci controller, but still no luck to detect BT hci controller.
Log is attached.
Since I am beginner to BT, Kindly correct me if I went wrong.
FerryT
Follow the instructions here https://htot.github.io/meta-intel-edison/4.3-bluetooth.html, but skip the btattach step (that is only for non-acpi).
FerryT
Just to be clear, you don't need to add any driver to the kernel while building, everything you need is already there. Also, you don't need to modprobe any modules, it goes automatic.
You only need to start the bluetooth service, rfkill unblock and then use bluetoothctl to pair/connect.
PSuta
Thanks for this suggestion.
Still I have some doubts.
1 . If you see the log, "rfkill unblock 1", is not setting to "Soft blocked: no".
In my case, we need to correct rfkill unblock 1 to rfkill unblock 0, in above given link.
2 . I would like to create cross-tool, so I ran "bitbake meta-toolchain", but where to get these bins created ?
3 . as a programmatic , point of view, how did we turn on HCI controller by systemctl start bluetooth_attach ?
Could you take me through in brief
3.1 linux internal working in kernel and bluez ?
3.2 netlink against BT stack layer i.e. l2cap, HCI with this systemd bluetooth_attach ?
Once again thanks for your quick and valuable response and support.
PSuta
FerryT
PSuta
Yes, you are right, I did not read that link in deep.
1 .
Now I think of speed up my activities and trying to add customized kernel recipe. So modified linux_custom.bb in "meta-intel-edison/meta-intel-edison-bsp/recipes-kernel/linux_custom". as
KBRANCH ?= "master"
require recipes-kernel/linux/linux-yocto.inc
LICENSE = "GPLv2"
LIC_FILES_CHKSUM = "file://COPYING;md5=bbea815ee2795b2f4230826c0c6b8814"
SRC_URI = "file://home/prityaa/documents/workspace/code_base/linux/kernel/linux/.git/;branch=${KBRANCH};protocol=file \
SRCREV ??= "f610818dfb680feb79ac57926ca2d8036b744de4"
COMPATIBLE_MACHINE = "edison"
do_kernel_configme[depends] += "bison-native:do_populate_sysroot flex-native:do_populate_sysroot"
# This one is necessary too - otherwise the compilation itself fails later.
DEPENDS += "openssl-native util-linux-native"
DEPENDS += "${@bb.utils.contains('ARCH', 'x86', 'elfutils-native', '', d)}"
~        KBRANCH ?= "master"
LICENSE = "GPLv2"
But still some files(.conf) need to be modified. still it takes 4.20*.bb file as in log file make_kernel.txt
2 . Would it be accepted if I changed code directly in "build/tmp/work-shared/qemux86/kernel-source/"
3 . Else how can I configure my local Linux kernel source tree in my build environment ?
4 . how can I speed up my kernel build (each time it's unpacking, configing and building) ?
Can not I make recipe that will build my external kernel source using make (since make only builds files which are changed ) . and images (zImage) can be installed in rootfs/initramfs ?
FerryT
1 bitbake looks at version numbers and uses the latest when needing to choose. But 'custom' is not a number. Easiest is to edit the existing recipe.
2 that won't work
3 here https://github.com/edison-fw/meta-intel-edison/blob/sumo32/meta-intel-edison-distro/conf/distro/poky...
4 I don't know. On my machine compiling takes 3 minutes. Maybe 5 for image build to complete. Would be nice if it could be faster, but didn't investigate.
PSuta
Thanks, I will try this and keep you posted.
Andriy_S_Intel
In some cases `ccache` can be used.
