Hello community,
I've downloaded my image from this website http://www.intel.com/content/www/us/en/support/boards-and-kits/intel-galileo-boards/000005614.html Software Downloads for Intel® Galileo Gen 2 Board (SD-Card Linux* Image), extracted the files with 7-zip and copied to a sd card.
I'm using FTDI cable and when booting ends, this is my prompt ( / # ). When I ran command uname -ra, this is the response:
/ # uname -ra
Linux (none) 3.8.7-yocto-standard # 1 Thu Oct 16 16:06:45 PDT 2014 i586 GNU/Linux
These are the files on root level of my sd card:
/media/mmcblk0p1 # ls
System Volume Information
boot
bzImage
core-image-minimal-initramfs-clanton.cpio.gz
image-full-galileo-clanton.ext3
Why is my Linux distribution listed as none ? Could somebody help me, please? Thanks.
Hi PaulaK,
I think it's a yocto-related issue. As the web site states (https://www.yoctoproject.org/ https://www.yoctoproject.org/):
It's not an embedded Linux distribution
– it creates a custom one for you
HTH,
Fernando.
Hi Fernando,
I'm kinda lost here, which image should I use? I found 3, apparently, different images on Intel's website.
https://software.intel.com/sites/landingpage/iotdk/board-boot-image.html IoT Download - Board Boot Image (iot-devkit-1.5-i586)
http://www.intel.com/content/www/us/en/support/boards-and-kits/intel-galileo-boards/000005614.html Software Downloads for Intel® Galileo Gen 2 Board (the image I downloaded, and got that "error")
https://software.intel.com/en-us/iot/hardware/galileo/downloads IoT - Intel® Galileo Board Download | Intel® Developer Zone (iot-devkit-201510010757-mmcblkp0-galileo.direct)
What is the "big linux" one? And what are the differences between them?
Hi PaulaK,
A very good question... Maybe this is one of the first problems I've faced, and I think I only have partial explanations... which I think is due to unexplained Intel changes/decisions. I've explained some of my/the problems in another recent thread:
Specifically about
I think that the first one is a previous version of the last one... but maybe I'm wrong. If that is true (someone at Intel should confirm), both are aka "EGLIBC based". I do not know what that exactly means, beyond that it is different from the other image, "UCLIBC based".
The image in the link http://www.intel.com/content/www/us/en/support/boards-and-kits/intel-galileo-boards/000005614.html Software Downloads for Intel® Galileo Gen 2 Board is also referred to as "UCLIBC based", and is (much) smaller than the "EGLIBC based" one. I used for several months without any problem for (Arduino) sketches persistency and some small size development (e.g. a small python web server). Then, someone pointed out that Intel stated in a page at its site that the UCLIBC based image was not going to be supported anymore (take a look at the first link above). Now that page at Intel does not exist anymore and I did not find any explanation about... maybe I should start a specific thread with this question...
I (strongly) suggest you download the image you need: start at http://galileo.intel.com/ http://galileo.intel.com/ and follow the step-by-step guide selecting the IDE/OS/etc. you are going to use. It's what I've made and It has worked so far. I'm not an expert (far of being one, actually) in the sense I've not developed a lot, I've mostly tried to learn and in some cases take advantage of the Galileo integrated hardware such as SD and Ethernet hardware.
HTH,
Fernando.
Hey Fernando,
Thank you so much for your answer.
I've followed the step by step tutorial with the image.direct and it all worked it out. The only thing I can not understand is why my image is Linux galileo and not Linux clanton like I see in many many threads. Is that a special image?
PaulaK wrote:
Hey Fernando,
Hi PaulaK,
I think yocto builds special images by its design goals, but nothing else beyond that, I don't know about image names/naming conventions neither yocto nor Intel yocto ones...
Fernando.
Hi PaulaK,
Are you talking about the hostnames? I mean root@galileo instead of root@clanton?
If this is the case it is just the hostname of the board, and can be edited in /etc/hostname. In the previous versions the hostname was clanton.
Charlie
Hi Charlie,
Yes, that's it. I thought if I didn't see Linux clanton(...), it was a sign that I wasn't running the big/full linux image that we generally see in threads.
Thank you very much. Can you please confirm me if the most recent image is from https://software.intel.com/en-us/iot/hardware/galileo/downloads IoT - Intel® Galileo Board Download | Intel® Developer Zone ?
Galileo running the image of link above.
root@galileo:~# cat /etc/version
201510010732
root@galileo:~# uname -ra
Linux galileo 3.8.7-yocto-standard # 1 Tue Sep 29 22:16:33 GMT 2015 i586 GNU/Linux
Many thanks to Charlie and Fernando
