Community
cancel
Showing results for
Search instead for
Did you mean:
Njang1
Bricked my edison board
Jump to solution
I bought a new Edison audrino shield board yesterday and tried to install stuff using my windows 10 64-bit machine and saw in the process my board got bricked. Here is the out put I get on the consle when boot the board
PSH KERNEL VERSION: b0182b2b
WR: 20104000
SCU IPC: 0x800000d0 0xfffce92c
PSH miaHOB version: TNG.B0.VVBD.0000000c
microkernel built 11:24:08 Feb 5 2015
******* PSH loader *******
PCM page cache size = 192 KB
Cache Constraint = 0 Pages
Arming IPC driver ..
Adding page store pool ..
PagestoreAddr(IMR Start Address) = 0x04899000
pageStoreSize(IMR Size) = 0x00080000
*** Ready to receive application ***
U-Boot 2014.04 (Jun 19 2015 - 12:05:55)
Watchdog enabled
DRAM: 980.6 MiB
MMC: tangier_sdhci: 0
In: serial
Out: serial
Err: serial
Hit any key to stop autoboot: 0
Target:ifwi
Partitioning already done...
Saving Environment to MMC...
Writing to redundant MMC(0)... done
GADGET DRIVER: usb_dnl_dfu
Any Idea on whats worng and how to recover from this ? I am not able to enter any key in u-boot bootup sequence.
Thanks in advance for any help.
Thanks & Regards,
Narendra
Pablo_M_Intel
Hi jvnr77,
Have you tried using the Flash Tool Lite to flash your board? You can find the instructions in this document /docs/DOC-98643 https://communities.intel.com/docs/DOC-98643. There you'll also find an alternative flashing method in case you don't get to flash your Edison with the first method.
PabloM_Intel
Pablo_M_Intel
Hi jvnr77,
PabloM_Intel
Njang1
Sorry for my late reply it worked. Thanks
