Community
cancel
Showing results for
Search instead for
Did you mean:
MRupp
Brillo OS - Successfully Flashing
I wrote an Instructions, i hope i doesnt forget any steps.....
  1. I compile it with Ubuntu 14.10 64 bit as VM on Windows 10
  2. first i establish a Build environment, like here : https://source.android.com/source/initializing.html Establishing a Build Environment | Android Open Source Project
  3. Install Repo : https://source.android.com/source/downloading.html Downloading the Source | Android Open Source Project --> at step "repo init" you take the brillo source :
repo init -u https://android.googlesource.com/brillo/manifest/ https://android.googlesource.com/brillo/manifest/
4.
repo sync
5.
source build/envsetup.sh
6.
lunch
7. Choose " edison-eng "
8.
make
- i get a few errors, first it doesnt find some files p.e. the wifi driver and bluetooth, i download them at git (after i google them ) after that it works without problems
9. The ".img" files at the "out" folder i flashed them with Intel Phone Flash Tool in Windows, in Ubuntu it doesnt work for me.
Here is the Result:
PSH KERNEL VERSION: b0182b2b
WR: 20104000
SCU IPC: 0x800000d0 0xfffce92c
PSH miaHOB version: TNG.B0.VVBD.0000000c
microkernel built 11:24:08 Feb 5 2015
******* PSH loader *******
PCM page cache size = 192 KB
Cache Constraint = 0 Pages
Arming IPC driver ..
Adding page store pool ..
PagestoreAddr(IMR Start Address) = 0x04899000
pageStoreSize(IMR Size) = 0x00080000
*** Ready to receive application ***
U-Boot 2015.10-rc4-g598bc0b (Oct 29 2015 - 17:35:55 -0700)
CPU: x86_64, vendor Intel, device 406a8h
Watchdog enabled
DRAM: 980.6 MiB
MMC: tangier_sdhci: 0, tangier_sdhci: 1
Using default environment
Model: Intel Edison
Net: Net Initialization Skipped
No ethernet found.
Valid Boot Flag
Setup Size = 0x00003c00
Magic signature found
Using boot protocol version 2.0c
Linux kernel version 3.10.89-brillo-edison+ (martata@ubuntu) # 1 SMP PREEMPT Wed Dec 23 09:27:05 PST 2015
Building boot_params at 0x00090000
Loading bzImage at address 100000 (6032496 bytes)
Initial RAM disk at linear address 0x205c5800, size 1226919 bytes
Kernel command line: "console=ttyMFD2 earlyprintk=ttyMFD2,keep androidboot.hardware=edison androidboot.selin ux=enforcing androidboot.serialno=c14748a4 androidboot.slot_suffix=_a"
Starting kernel ...
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.10.89-brillo-edison+ (martata@ubuntu) (gcc version 4.9 20150123 (prerelease) (GCC) ) # 1 SMP PREEMPT Wed Dec 23 09:27:05 PST 2015
[ 0.000000] e820: BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x0000000000097fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000003ffffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000004000000-0x0000000005ffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000006000000-0x000000003f4fffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000003f500000-0x000000003fffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec04000-0x00000000fec07fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.6 present.
[ 0.000000] e820: last_pfn = 0x3f500 max_arch_pfn = 0x1000000
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] total RAM covered: 982M
[ 0.000000] Found optimal setting for mtrr clean up
[ 0.000000] gran_size: 64K chunk_size: 512M num_reg: 5 lose cover RAM: 0G
[ 0.000000] init_memory_mapping: [mem 0x00000000-0x000fffff]
[ 0.000000] init_memory_mapping: [mem 0x37400000-0x375fffff]
[ 0.000000] init_memory_mapping: [mem 0x34000000-0x373fffff]
[ 0.000000] init_memory_mapping: [mem 0x00100000-0x03ffffff]
[ 0.000000] init_memory_mapping: [mem 0x06000000-0x33ffffff]
[ 0.000000] init_memory_mapping: [mem 0x37600000-0x377fdfff]
[ 0.000000] RAMDISK: [mem 0x205c5800-0x206f1fff]
[ 0.000000] 125MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x00001000-0x00ffffff]
[ 0.000000] Normal [mem 0x01000000-0x377fdfff]
[ 0.000000] HighMem [mem 0x377fe000-0x3f4fffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x00001000-0x00097fff]
[ 0.000000] node 0: [mem 0x00100000-0x03ffffff]
毛毛1
hi Sangi, I met the same problem with you. After flashing the brillo image to edison board for arduino with flash tool, the board came in fastboot mode as follows.
Have you resolved this problem ? Can you share the solution with me. Thanks a lot.
the result :
U-Boot 2015.10-rc4-g598bc0b (Oct 29 2015 - 17:36:00 -0700)
Watchdog enabled
DRAM: 980.6 MiB
Model: Intel Edison
No ethernet found.
FASTBOOT MODE...
skuma76
U changed anything in source code ?
AGudi1
Hi All
But what are the advantages of Brillo over Yacto, what type of projects can we do with Brillo.
Appreciate your response.
sshai7
Hi Martata
upto build it is working fine.but when i am trying to compile using $make i am getting errors .
please once go to the attachment try to help me to comeout from this problem.
ishaq
TYoo
Hi, Martata. I'm Tylor Yoo.
Thank you for your manual. I could build Brillo source code.
Recently, I'm uploading Brillo's image to Edison kit for arduino.
But I have trouble in flashing Brillo's image files.
Can you tell me names of ".img" files? My environments don't recognize the files.
Or can you write the process more specifically?
Have a nice day.
MRupp
HI, i try to writing a more detailed instruction, but i need some more days.
sshin12
Hello Marta,
Good Day!
It would be of great help if you explain in brief how you managed to flash the *.img brillo images to Edison?
I tried using the steps for fastboot
https://android.googlesource.com/device/intel/edison/+/master/flash_tools/brillo-flashall-edison.sh flash_tools/brillo-flashall-edison.sh - device/intel/edison - Git at Google
ut bootloader was not built from Brillo sources-boot-edison.bin.
I tried to use Intel phone flash tool, but it doesnot accept *.img files.
I am very curious to get my Edison booted with Brillo.... any help would be appreciated!
Sangi
skuma76
Hey,i compiled succesfully the brillo os on ubuntu.i did't find the in out folder which ".img" file is required,please tell me exact path,Also how to flash brillo build image on intel edison board for ubuntu platform.
skuma76
Thanks Martata,
brillo os successfully flash on intel edison board,i want to try using command configure_edison --wifi,i got command is not found,how can solve this?
sshin12
Singhania,
Did you use brillo-flashall-edison.sh for flashing? So how did you take your edison in fastboot mode?
Thanks in advance
Cheers
Sangi
skuma76
Hi Sangi,
i don't use brillo-flashall-edison.sh for flashing,i used intel phone tools and upload json script file for flashing,please read the json script file and check the which file ism required ti add and also copy all file .img ,.bin and ifwi file in flash_tools folder.
i used edison.sh for flashing in intel edison board for yocta image with help 'edison-src' source code.i successful done without using any phone flash tool.
AAman3
Hi Martata,
In "lunch" there are may options turned up. I want to load Brillo on Emulator which one shall I choose?
Thanks and Regards,
Aman Dalmia
skuma76
Hi aman,
u can choose option in lunch depends up on your hardware( like Edison for intel edison board ).
瑶瑶_王
Hi,witch Edsion board do you used?can you give me a link to buy?
PGaje
Successfully flash Brillo OS in edision board but now, how can first "Hello World" program build for it.
hkang9
ninja: no work to do.
[1/2] soong_build docs out/soong/.bootstrap/docs/soong_build.html
FAILED: out/soong/.bootstrap/docs/soong_build.html
out/soong/.bootstrap/bin/soong_build -b out/soong --docs out/soong/.bootstrap/docs/soong_build.html ./Android.bp
error: frameworks/native/cmds/atrace/Android.bp:3:1: "atrace" depends on undefined module "libhwbinder"
error: frameworks/native/cmds/atrace/Android.bp:3:1: "atrace" depends on undefined module "android.hidl.manager@1.0"
error: frameworks/native/cmds/atrace/Android.bp:3:1: "atrace" depends on undefined module "libhidlbase"
error: frameworks/native/cmds/atrace/Android.bp:3:1: "atrace" depends on undefined module "libhidltransport"
[2/2] out/soong/.bootstrap/bin/soong_build out/soong/build.ninja
FAILED: out/soong/build.ninja
out/soong/.bootstrap/bin/soong_build -b out/soong -d out/soong/build.ninja.d -o out/soong/build.ninja Android.bp
ninja: build stopped: subcommand failed.
build/core/soong.mk:29: recipe for target 'run_soong' failed
make: *** [run_soong] Error 1
During compiling brillo, it occurs errors like above.
What should I do?
Help me
PGaje
@kkang follow my step.
-> Build bdk in ubuntu 14.04 LTS.
-> bdk should present in root directory and then after building brillo image.
-> First set bdk path:
# export BDK_PATH=/
-> After that, run environment script.
# ${BDK_PATH}/build/envsetup.sh
-> Set target board using lunch command and note that run lunch command more than 4 times because sometimes not set target successfully.
# lunch
-> Finally run below command:
# m -j20
YNL
I tried above steps i'm getting these errors. can anyone help me this
