Intel® Makers
9872 Discussions
Brillo on Intel Edison not working for me
NKuma21
Hi All,
i installed fastboot bootloader on intel edison but not able to run any command on terminal. Instructions which i followed is below
https://developers.google.com/brillo/eap/guides/get-started/board-bringup# powering_the_board https://developers.google.com/brillo/eap/guides/get-started/board-bringup# powering_the_board
1. sudo apt-get install p7zip-full gdebi-core gdebi
2.sudo dpkg -i phoneflashtoollite__linux_x86_64.deb
3. m dist
4. 1. phoneflashtoollitecli -f out/out-edison/dist/-flashfiles-eng..zip
then after this
sudo screen /dev/ttyUSB0 115200
please help me to out of this...:-)
thanks in advance...
Neeraj
Diego_V_Intel
Hi NeerajHCL,
Some time ago another user posted a guide about how to flash Brillo on Edison; he mentioned that he was able to flash the image successfully. I recommend you to check his guide; it might be helpful for you: . Anyhow, the official image supported by us is Yocto. If you have questions regarding the Brillo image, I recommend you to contact its developers directly: https://developers.google.com/brillo/ Brillo | Google Developers
Diego
Diego_V_Intel
Hi NeerajHCL,
Diego
NKuma21
