And does not open 192.168.2.15 and 170.34.55.90 (local Edison IP) when connected to WiFi.
systemctl start wpa_supplicant
ifconfig wlan0 down
ifconfig usb0 down
ifconfig wlan0 up
ifconfig usb0 up
ping intel.com - OK
ping 170.34.55.90 (local Edison IP) - OK
But when open this IP at computer/phone browser, see error message "Can not open this page".
What's wrong?
- Tags:
- WiFi
What are the version and image of Intel edison?
Try to update and restart Apache2 in Intel Edison.
root@edison:~# echo src/gz all http://repo.opkg.net/edison/repo/all http://repo.opkg.net/edison/repo/all > /etc/opkg/base-feeds.conf
root@edison:~# echo src/gz edison http://repo.opkg.net/edison/repo/edison http://repo.opkg.net/edison/repo/edison >> /etc/opkg/base-feeds.conf
root@edison:~# echo src/gz core2-32 http://repo.opkg.net/edison/repo/core2-32 http://repo.opkg.net/edison/repo/core2-32 >> /etc/opkg/base-feeds.conf
root@edison:~# opkg update
root@edison:~# opkg install apache2
root@edison:~# systemctl reenable apache2
root@edison:~# systemctl restart apache2
root@edison:~# reboot
After reboot and login, check weather Apache2 is loaded, enabled and Running in your Intel Edison.
root@edison:~# systemctl status apache2
Restart your wifi.
After setting up your Wifi config (configure_edison --wifi) again, you should be able to see the webpage [It works!] in your web browser by using the IP address of the board.
Hi nvozniy,
Any updates on this issue?
Hi Nvozniy,
Did you try Yeong's recommendation? Did it work?
We will appreciate if you let us know your results.
Have a nice day.
-Leonardo
