Intel® Makers
9872 Discussions
Buen dia cuento con una Compute Stick stck1a32wfc El problema es que cuando la apago y la vuelvo a ecender se desconfigura todo y tengo que volver a recuperar el sistema win 8.1 acaso siempre tiene que estar encendida o conectda a la toma de corriente
Community Manager
En si el error es siempre tiene que tener corriente para que no se desconfigure ???
n_scott_pearson
Super User Retired Employee
The translator is not doing well; I cannot understand what you are trying to say. Please be more verbose in your explanation. Avoid using colloquialisms.
IUman
Hello Malic3,
Thank you for contacting the Intel community.
In this case, if you shutdown the Intel® Compute stick, the system is not suppose to go in recovery mode every time you restart it, but if this happening on your system for no reason you can try updating the BIOS, you can download the latest BIOS version for your system here:
https://downloadcenter.intel.com/download/26540/BIOS-Update-FCBYT10H-86A-?product=86612 BIOS Update [FCBYT10H.86A]
Please see http://www.intel.com/content/www/us/en/support/boards-and-kits/intel-compute-stick/000006039.html F7 BIOS Update Instructions for Intel® Compute Stick
Ivan U.
IUman
Hello ,
I'm following on this post to ask you if your issue has been resolved or if you need further assistance.
Ivan.
