Hi all,
I'm developing on the Intel Edison usning the Arduino IDE. My sketch uses the WiFi library. I notice that if my sketch calls WiFiClient::stop() then it will randomly crashes without any explanation. The reason I need WiFiClient::stop() is because my sketch needs to repeatedly query a specific URL every 1 second, and if I don't call stop() on existing clients then I'll run out of sockets to use.
To investigate the culprit I run Valgrind on my sketch and it says (Highlighted texts are the important bits):
==6239== Use of uninitialised value of size 4
==6239== at 0x8058C73: WiFiClient::stop() (WiFiClient.cpp:272)
==6239== by 0x804BEF8: HTTP::Client::post(std::string, short, std::string, std::map, std::allocator > >) (http_client.cpp:32)
==6239== by 0x804D3A7: SmartBotsAPI::get_pending_cmds(std::vector >&) (smartbots_api.cpp:81)
==6239== by 0x805082F: loop() (smartbots_hub.ino:45)
==6239== by 0x805F35D: main (main.cpp:114)
==6239== Uninitialised value was created by a stack allocation
==6239== at 0x804D256: SmartBotsAPI::get_pending_cmds(std::vector >&) (smartbots_api.cpp:68)
==6239==
==6239== Invalid write of size 4
==6239== Address 0x2 is not stack'd, malloc'd or (recently) free'd
==6239==
==6239==
==6239== Process terminating with default action of signal 11 (SIGSEGV)
==6239== Access not within mapped region at address 0x2
(loop, SmartBotsAPI, HTTP are my functions/classes/namespaces)
Looking at WiFiClient.cpp at around the line 272 I found the following (https://github.com/01org/corelibs-edison/blob/1ed2b520c0c089dea70bdd082aa0fb1dd93f4e11/libraries/WiF... L272 GitHub link):
if (_inactive_counter != NULL) // Line 271
*_inactive_counter = 0; // Line 272
And in WiFiClient.h _inactive_counter is defined as follow (https://github.com/01org/corelibs-edison/blob/1ed2b520c0c089dea70bdd082aa0fb1dd93f4e11/libraries/WiF... L35 GitHub link):
int *_inactive_counter;
_inactive_counter is a pointer to an int variable, however it isn't initialized to any variables. Thus, it's a wild pointer pointing to an undefined address in memory. And of course when dereferencing/writing a value into a wild pointer, there'll be a very high chance that the address is invalid, and the program will terminated because of segmentation fault.
Looking further, there's only one place where _inactive_counter is assigned to a variable. It's in WiFiServer.cpp at line 131 (https://github.com/01org/corelibs-edison/blob/1ed2b520c0c089dea70bdd082aa0fb1dd93f4e11/libraries/WiF... L131 Github link)
pclients[sock]._inactive...
