Hi. My OS is Ubuntu 14.04.4 LTS 32-bit.
I use iot-devkit-yp-poky-edison-20160315.zip source package (sources for Release 3.0 Yocto* complete image) Achieve md5:ee6ef7a6514e7c2c1bb9c085e165ced7, modified 06 May 2016 from here http://iotdk.intel.com/src/3.0/edison/ http://iotdk.intel.com/src/3.0/edison/ .
unzip iot-devkit-yp-poky-edison-20160315.zip
cd iot-devkit-yp-poky-edison-20160315/
mkdir bitbake_download_dir
mkdir bitbake_sstate_dir
./poky/meta-intel-edison/setup.sh --dl_dir=./bitbake_download_dir --sstate_dir=./bitbake_sstate_dir
I see:
** Success **
SDK will be generated for linux32 host
Now run these two commands to setup and build the flashable image:
cd /home/user/yocto/iot-devkit-yp-poky-edison-20160315/poky/out/linux32
source poky/oe-init-build-env
bitbake edison-image
Start building:
cd ./poky/out/linux32
In the result:
NOTE: Preparing runqueue
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
WARNING: Failed to fetch URL git://git.eclipse.org/gitroot/paho/org.eclipse.paho.mqtt.c.git;protocol=http, attempting MIRRORS if available
ERROR: Fetcher failure: Fetch command failed with exit code 128, output:
Cloning into bare repository '/home/user/yocto/iot-devkit-yp-poky-edison-20160315/bitbake_download_dir/git2/git.eclipse.org.gitroot.paho.org.eclipse.paho.mqtt.c.git'...
fatal: repository ' http://git.eclipse.org/gitroot/paho/org.eclipse.paho.mqtt.c.git/' not found
ERROR: Function failed: Fetcher failure for URL: 'git://git.eclipse.org/gitroot/paho/org.eclipse.paho.mqtt.c.git;protocol=http'. Unable to fetch URL from any source.
ERROR: Logfile of failure stored in: /home/user/yocto/iot-devkit-yp-poky-edison-20160315/poky/out/linux32/build/tmp/work/core2-32-poky-linux/paho-mqtt/3.1-r1/temp/log.do_fetch.8768
ERROR: Task 1066 (/home/user/yocto/iot-devkit-yp-poky-edison-20160315/poky/out/linux32/poky/meta-intel-iot-middleware/recipes-connectivity/paho-mqtt/paho-mqtt_3.1.bb, do_fetch) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2059 tasks of which 2052 didn't need to be rerun and 1 failed.
Waiting for 0 running tasks to finish:
Summary: 1 task failed:
Summary: There was 1 WARNING message shown.
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
The error you're receiving is very similar to the one on /message/390323# 390323 https://communities.intel.com/message/390323# 390323 .
Also, there are a few threads that discuss building the new image you can find useful.
Take a look at
- /message/395819# 395819 https://communities.intel.com/message/395819# 395819
- /message/397345# 397345 https://communities.intel.com/message/397345# 397345
Take a look at
