Intel® Makers
9881 Discussions
Building Yocto image on Ubuntu 15 with GCC5
EFedo2
Hello everyone!
Wanted to share a chain of patches and fixes that make building the default Edison Yocto image possible with the new GCC versions
I encountered problems building ncurses, binutils, glibc, and subversion
Here are the required patches:
  1. Ncurses: add -P flag like here: https://dev.openwrt.org/ticket/19749 https://dev.openwrt.org/ticket/19749
  2. binutils: fix if statement in out/build/tmp directory displayed during compilation like here: https://github.com/resin-io/meta-resin/blob/master/meta-resin-common/recipes-devtools/binutils/binut... https://github.com/resin-io/meta-resin/blob/master/meta-resin-common/recipes-devtools/binutils/binut...
  3. glibc cross-localedef-native: add -fgnu89-inline to CFLAGS like here: http://patchwork.openembedded.org/patch/96873/ http://patchwork.openembedded.org/patch/96873/
  4. Subversion configure fail: modify subversion_1.8.9.bb to have the following lines:
Instead of inherit gettext
Put inherit gettext pythonnative
Under
export LDFLAGS += " -L${STAGING_LIBDIR} "
Add following flags
CPPFLAGS += "-P"
BUILD_CPPFLAGS += "-P
incomplete patch for this issue here(build cpp flags is not added and therefore build fails): http://git.yoctoproject.org/cgit.cgi/poky/commit/?id=9b19d6548a345009a6de79a6820c07a72054d961 poky - Poky Build Tool and Metadata
example how it should be done here: http://cgit.openembedded.org/cgit.cgi/openembedded-core/tree/meta/recipes-devtools/subversion/subver... openembedded-core - OpenEmbedded Core layer
Sincerely hope it will help somebody!
