Intel® Makers
9868 Discussions
Building xFSTK on Ubuntu 14.04 (32-bit) for flashing Edison
DHunt5
Valued Contributor I
If you want to use the flashall.sh method of installing operating systems on your Edison, then it's more than likely that you'll need to install xFSTK. I've spent a few hours trying to get it building, and have failed to get it building on a 64-bit OS, so I finally got it working on Ubuntu 14-04 (32-bit). Once I got the 32-bit OS installed, it was rather straightforward, but with a different method to that on the front of the xFSTK sourceforge page.
Download the latest version of xFSTK onto your Ubuntu 14.04 32-bit system from http://sourceforge.net/projects/xfstk/files/ here and extract.
tar xvfz xfstk-dldr-linux-source-1.7.2.tar.gz
cd xfstk-build/linux-source-package
sudo apt-get install g++ qtcreator build-essential devscripts libxml2-dev alien doxygen graphviz libusb-dev libboost-all-dev
Also, a couple of missing packages needed for the build and packager not mentioned on the sourceforge page
sudo apt-get install libqt4-dev qt4-qmake
Set a couple of environment variables (the packaging at the end of the build script will fail if these are not set)
export DISTRIBUTION_NAME=ubuntu14.04
export BUILD_VERSION=0.0.0
Now to tweak the build script for a faster compilation. Edit 'package-xfstk-downloader-linux.sh' and search for the line with 'make --version' and add a '-j x' onto the end, where x is the number of processors you have available on your build system. Example
make --version -j 6
now run the script to build and package xFSTK:
./package-xfstk-downloader-linux.sh
If all goes well, that will build everything and produce an installable .deb package in ./xfstk-build/installer/linux/ubuntu/
and and installable rpm package in ./xfstk-build/installer/linux/fedora/
You can then install the .deb package using 'dpkg -i'
Rgds,
Dave.
Matthias_H_Intel
built it fine on OpenSuse 12.2 x64 some days ago. Just some dependencies to figure out. Built fine and works great
TKanw
I was able to get this working on Ubuntu 13.10 64-bit after a bit of playing with it.
I had to additionally:
  • Install libusb-1.0-0-dev
  • Symlink /usr/lib/x86_64-linux-gnu/libusb-1.0.a at /usr/lib/libusb.a
I also built using their cmake instructions rather than their package builder, which didn't seem to work. Instead, I ran:
mkdir build
cd build
cmake ..
make package
This make a .deb, which I installed with dpkg -i with no problems.
Community Manager
Hi @David_J_Hunt ,.
I've followed all the steps above. But when I run the last command,
./package-xfstk-downloader-linux.sh , it shows the following error:-
g++: error: /usr/lib/libusb.a: No such file or directory
make[4]: *** [../../../xfstk-build/bin/debug/downloader-solo/xfstk-dldr-solo] Error 1
make[4]: Leaving directory `/home/x3/Downloads/xfstk-build/linux-source-package/xfstk-projects/core/downloader-solo'
make[3]: *** [debug-all] Error 2
make[3]: Leaving directory `/home/x3/Downloads/xfstk-build/linux-source-package/xfstk-projects/core/downloader-solo'
make[2]: *** [sub-downloader-solo-make_default-ordered] Error 2
make[2]: Leaving directory `/home/x3/Downloads/xfstk-build/linux-source-package/xfstk-projects/core'
make[1]: *** [sub-core-make_default-ordered] Error 2
make[1]: Leaving directory `/home/x3/Downloads/xfstk-build/linux-source-package/xfstk-projects'
make: *** [sub-xfstk-projects-make_default-ordered] Error 2
make: Leaving directory `/home/x3/Downloads/xfstk-build/linux-source-package'
ERROR: make -w step problem
any solution please ??
Matthias_H_Intel
have you installed libusb???
Community Manager
yes.. libusb-dev is installed
I have done this before. but at that time everything went fine. but this time it is throwing error. I don't know why
Matthias_H_Intel
but apparently it's not in /usr/lib/libusb.a?
Matthias_H_Intel
so you might have to add to LD_LIBRARY_PATH
Community Manager
right now I'm working on taht only.
my libusb.a file was stored in /usr/lib/i386-gnu-linux/libusb.a so I just transferred it into /usr/lib/ folder.
and now the process completed successfully..
MMunu
I am new to Ubuntu and this forum. Trying to get XFSTK build but I am getting the same error. I have installed libusb but unable to find the file called libusb.a anywhere.
sudo apt-get install libusb-1.0-0-dev
Please help.
CCarc
Hi, i am having some issues compiling. Before checking all every one comment, i still get some errors.
Do you have some ideas?
Andriy_S_Intel
The latest code of xFSTK with community fixes is available on GitHub: https://github.com/edison-fw/xFSTK
