Intel® Makers
9873 Discussions
C compiled file using eclipse crash after 5 Minutes
CWong12
I saw a post discuss about /thread/99180?start=0&tstart=0 Sketch Crash After 5 Minutes. But the problem was solved using https://downloadcenter.intel.com/downloads/eula/24910/Intel-Edison-Software-Release-2-1?httpDown=htt... Intel Edison Software Release 2.1 . However, i tried to re-flash the new image which is version 146, But the crashing still happen. I am using update-rc.d to put my C application to run on startup.
Cheyne
Pedro_M_Intel
Hello cheyne,
The 146 image has better stability when using the Arduino IDE, if you are using Eclipse using the 146 image won't help you, so I would suggest you to flash your board to the latest image (which can be found in http://software.intel.com/en-us/iot/hardware/edison/downloads Intel® Edison Downloads). My guesses would be that there might be something wrong with the script itself or that something could be wrong with update-rc.d. Does your script work fine when uploading it from Eclipse? I mean, if you don't start it using update-rc.d.
Peter.
CWong12
Hi Peter,
It can run more than 5 minutes by using eclipse in debug mode. However, when i put it to run on its own upon startup using update-rc and it just go unresponsive. Pls advise.
CWong12
Hi Peter,
Solved the issue by writing a script to run my application instead. Thanks!
