Intel® Makers
9881 Discussions
C1000 (SCSS.H PROBLEM)
MRosn
# ifndef __SCSS_H__
# define __SCSS_H__
# include "qm_common.h"
# include "qm_soc_regs.h"
# include
* System control subsystem for Quark Microcontrollers.
* @defgroup groupSCSS System Control Subsystem
# define OSC0_SI_FREQ_SEL_MASK (0xFFFFFCFF)
* When using an external crystal, this value must be set to the number of
* system ticks per micro second. The expected value is 32 ticks for a 32MHz
* crystal.
# define SYS_TICKS_PER_US_XTAL (32)
# define SYS_TICKS_PER_US_32MHZ (32)
# define SYS_TICKS_PER_US_16MHZ (16)
# define SYS_TICKS_PER_US_8MHZ (8)
# define SYS_TICKS_PER_US_4MHZ (4)
* System clock divider type.
typedef enum {
CLK_SYS_DIV_1,
CLK_SYS_DIV_2,
CLK_SYS_DIV_4,
CLK_SYS_DIV_8,
# if (QUARK_D2000)
CLK_SYS_DIV_16,
CLK_SYS_DIV_32,
CLK_SYS_DIV_64,
CLK_SYS_DIV_128,
# endif
CLK_SYS_DIV_NUM
} clk_sys_div_t;
* System clock mode type.
typedef enum {
CLK_SYS_HYB_OSC_32MHZ,
CLK_SYS_HYB_OSC_16MHZ,
CLK_SYS_HYB_OSC_8MHZ,
CLK_SYS_HYB_OSC_4MHZ,
CLK_SYS_RTC_OSC,
CLK_SYS_CRYSTAL_OSC
} clk_sys_mode_t;
* Peripheral clock divider type.
typedef enum {
CLK_PERIPH_DIV_1,
CLK_PERIPH_DIV_2,
CLK_PERIPH_DIV_4,
CLK_PERIPH_DIV_8
} clk_periph_div_t;
* GPIO clock debounce divider type.
typedef enum {
CLK_GPIO_DB_DIV_1,
CLK_GPIO_DB_DIV_2,
CLK_GPIO_DB_DIV_4,
CLK_GPIO_DB_DIV_8,
CLK_GPIO_DB_DIV_16,
CLK_GPIO_DB_DIV_32,
CLK_GPIO_DB_DIV_64,
CLK_GPIO_DB_DIV_128
} clk_gpio_db_div_t;
* External crystal clock divider type.
typedef enum {
CLK_EXT_DIV_1,
CLK_EXT_DIV_2,
CLK_EXT_DIV_4,
CLK_EXT_DIV_8
} clk_ext_div_t;
* RTC clock divider type.
typedef enum {
CLK_RTC_DIV_1,
CLK_RTC_DIV_2,
CLK_RTC_DIV_4,
CLK_RTC_DIV_8,
CLK_RTC_DIV_16,
CLK_RTC_DIV_32,
CLK_RTC_DIV_64,
CLK_RTC_DIV_128,
CLK_RTC_DIV_256,
CLK_RTC_DIV_512,
CLK_RTC_DIV_1024,
CLK_RTC_DIV_2048,
CLK_RTC_DIV_4096,
CLK_RTC_DIV_8192,
CLK_RTC_DIV_16384,
CLK_RTC_DIV_32768
} clk_rtc_div_t;
* SCSS peripheral clock register type.
typedef enum {
CLK_PERIPH_REGISTER = BIT(0),
CLK_PERIPH_CLK = BIT(1),
CLK_PERIPH_I2C_M0 = BIT(2),
# if (QUARK_SE)
CLK_PERIPH_I2C_M1 = BIT(3),
# endif
CLK_PERIPH_SPI_S = BIT(4),
CLK_PERIPH_SPI_M0 = BIT(5),
# if (QUARK_SE)
CLK_PERIPH_SPI_M1 = BIT(6),
# endif
CLK_PERIPH_GPIO_INTERRUPT = BIT(7),
CLK_PERIPH_GPIO_DB = BIT(8),
# if (QUARK_SE)
CLK_PERIPH_I2S = BIT(9),
# endif
CLK_PERIPH_WDT_REGISTER = BIT(10),
CLK_PERIPH_RTC_REGISTER = BIT(11),
CLK_PERIPH_PWM_REGISTER = BIT(12),
CLK_PERIPH_GPIO_REGISTER = BIT(13),
CLK_PERIPH_SPI_M0_REGISTER = BIT(14),
# if (QUARK_SE)
CLK_PERIPH_SPI_M1_REGISTER = BIT(15),
# endif
CLK_PERIPH_SPI_S_REGISTER = BIT(16),
CLK_PERIPH_UARTA_REGISTER = BIT(17),
CLK_PERIPH_UARTB_REGISTER = BIT(18),
CLK_PERIPH_I2C_M0_REGISTER = BIT(19),
# if (QUARK_SE)
CLK_PERIPH_I2C_M1_REGISTER = BIT(20),
CLK_PERIPH_I2S_REGISTER = BIT(21),
CLK_PERIPH_ALL = 0x3FFFFF
# elif(QUARK_D2000)
CLK_PERIPH_ADC = BIT(22),
CLK_PERIPH_ADC_REGISTER = BIT(23),
CLK_PERIPH_ALL = 0xCFFFFF
# else
# error "Unsupported / unspecified interrupt controller detected."
# endif
} clk_periph_t;
* Change the operating mode and clock divisor of the system
* clock source. Changing this clock speed affects all
* peripherals.
* @param [in] mode System clock source operating mode
* @param [in] div System clock divisor.
* @return qm_rc_t QM_RC_OK on success, error code otherwise.
qm_rc_t clk_sys_set_mode(const clk_sys_mode_t mode, const clk_sys_div_t div);
* Change ADC clock divider value. The new divider value is set to N, where N is
* the value set by the function and is between 1 and 1024.
* @brief Change divider value of ADC clock.
* @param [in] div Divider value for the ADC clock.
qm_rc_t clk_adc_set_div(const uint16_t div);
* Change Peripheral clock divider value. The maximum divisor is
* /8. These peripherals include GPIO Inter...
Community Manager
Hello Amie_coolman93
Thank you for contacting the Intel Communities, I understand you have some questions related to your Intel® Quark™ SE Microcontroller C1000
Please be aware I will be re-routing your post to the forum support team in charge of this product so you can get this handled at the soonest.
Esteban C
