Community
cancel
Showing results for
Search instead for
Did you mean:
MRosn
C1000 WITH DHT11 (Serial monitor do not show temperature value)
# include "qm_gpio.h" /*Calling QMSI GPIO API. See section 3.1 for more details. */
# include "clk.h"
# include "qm_pinmux.h"
# include "qm_pin_functions.h"
//# include "qm_scss.h" /*Calling QMSI SCSS API*/
//# include "qm_ss_gpio.h"
# define PIN_DHT11 21
# define LED_PIN_ID (QM_PIN_ID_55)
# define PIN_MUX_FN (QM_PIN_55_FN_GPIO_21)
//static qm_ss_gpio_state_t state_ss;
static qm_gpio_state_t state_ss;
static void pin_mux_setup(void)
qm_pmux_select(LED_PIN_ID, PIN_MUX_FN);
uint32_t expectPulse(bool level) /*function to read DHT11 pulse*/
uint32_t count = 0;
while (qm_gpio_read_pin(QM_GPIO_0, PIN_DHT11, &state_ss) == level) {
if (count++ >= 100000) { /* 1 millisecond to read DHT11 pulse */
return 0; /* Exceeded timeout, fail. */
return count;
int main()
qm_gpio_port_config_t cfg;
pin_mux_setup();
uint32_t cycles[80], i; /* same cycle number as in the DHT11 library */
uint8_t data[5]; /* same data number as in the DHT11 library */
/* Reset 40 bits of received data to zero. */
data[0] = data[1] = data[2] = data[3] = data[4] = 0;
QM_PUTS("DHT11 example");
cfg.direction = BIT(PIN_DHT11);
qm_gpio_set_config(QM_GPIO_0, &cfg); /* Act like Arduino's pinMode. Setting
* DHT11 pin on D2000 dev board as input.
* See section 3.3 for more details. */
while(1){
//cfg.direction = BIT(PIN_DHT11);
//qm_gpio_set_config(QM_GPIO_0, &cfg);
qm_gpio_set_pin(QM_GPIO_0, PIN_DHT11); /* set HIGH to DHT11 pin */
clk_sys_udelay(250000); /* 250 ms */
/* The three line above written in QMSI and are similar to Arduino's
*'digitalWrite(PIN_DHT11,HIGH);' which is to let pull-up raise data line level
* And start reading the DHT11. After that proceed with 250 ms delay.
* See section 3.4 for more details.
/* Send DHT11 start signal */
qm_gpio_clear_pin(QM_GPIO_0, PIN_DHT11); /* set DHT11 pin LOW */
clk_sys_udelay(20000); /* 20 ms */
qm_gpio_set_pin(QM_GPIO_0, PIN_DHT11); /* set DHT11 pin HIGH */
clk_sys_udelay(40); /* 40 us */
cfg.direction = 0;
qm_gpio_set_config(QM_GPIO_0, &cfg); /* Setting the DHT11 pin as output to
* start listening from the DHT11
clk_sys_udelay(10); /* 10 us */
if(!expectPulse(false))
QM_PUTS("Timeout waiting for start signal low pulse.");
continue;
if(!expectPulse(true))
QM_PUTS("Timeout waiting for start signal high pulse.");
continue;
for (i=0; i<80; i+=2) {
cycles[i] = expectPulse(0);
cycles[i+1] = expectPulse(1);
// Inspect pulses and determine which ones are 0 (high state cycle count < low
// state cycle count), or 1 (high state cycle count > low state cycle count).
for (i=0; i<40; ++i) {
uint32_t lowCycles = cycles[2*i];
uint32_t highCycles = cycles[(2*i)+1];
if ((lowCycles == 0) || (highCycles == 0)) {
QM_PUTS("Timeout waiting for pulse.");
continue ;
data[i/8] <<= 1;
/*Now compare the low and high cycle times to see if the bit is a 0 or 1. */
if (highCycles > lowCycles) {
/* // High cycles are greater than 50us low cycle count, must be a 1. */
data[i/8] |= 1;
// Else high cycles are less than (or equal to, a weird case) the 50us low
// cycle count so this must be a zero. Nothing needs to be changed in the
// stored data.
QM_PRINTF("Receive %d %d %d %d %d\n",data[0],data[1],data[2],data[3],data[4]);
uint8_t TempF = (data[2]*1.8) +32;
QM_PRINTF("h : %d, t : %d, f ; %d r\n", data[0],data[2],TempF);
/* Check we read 40 bits and that the checksum matches. */
if (data[4] == ((data[0] + data[1] + data[2] + data[3]) & 0xFF)) {
else
QM_PUTS("Checksum failure!");
return 0;
The result from serial monitor:
-The code do not read the temperature value : uint8_t TempF = (data[2]*1.8) +32;
