Why the code do not read the calculation I used and why the C1000 serial monitor do not show any value or read the sensor?
Right now the sensor do not give a correct reading value in Serial monitor:
# include "qm_gpio.h" /*Calling QMSI GPIO API. See section 3.1 for more details. */
# include "clk.h"
# include "qm_pinmux.h"
# include "qm_pin_functions.h"
# include "stdio.h"
# include "stdlib.h"
# include "math.h"
# define PIN 22
# define DHT_PIN_ID (QM_PIN_ID_56)
# define PIN_MUX_FN (QM_PIN_56_FN_GPIO_22)
# define DELAY 2500000
char message1[] = "Tempt = 00.0 C";
char message2[] = " RH = 00.0 %";
short Time_out;
uint8_t T_byte1, T_byte2, RH_byte1, RH_byte2, Checksum;
uint16_t Temp, RH;
//static qm_gpio_state_t state;
void start_signal()
qm_gpio_port_config_t cfg;
cfg.direction = 0; //cnfgre pin as o/p
qm_gpio_set_config(QM_GPIO_0, &cfg); //cnfgre pin as o/p
qm_gpio_clear_pin(QM_GPIO_0, PIN); //pin o/p LOW
QM_PUTS("O/P LOW");
clk_sys_udelay(25000); //25ms
qm_gpio_set_pin(QM_GPIO_0, PIN); // pin o/p HIGH
QM_PUTS("O/P HIGH");
clk_sys_udelay(30000); //30ms
cfg.direction = BIT(PIN); //cnfgre pin as i/p
signed short check_response()
clk_sys_udelay(40000); //40ms
//clk_sys_get_ticks_per_us;
if(!PIN) // Read and test if connection pin is low
clk_sys_udelay(80); //waiting till sensors starts sending data
if(PIN)
clk_sys_udelay(50); //just in case delay
QM_PUTS("LOW");
return 1;
uint8_t read_data()
<p style="font-family: intel-clear, arial, helvetica, 'helve...Link Copied
Thank you for reaching out to Intel® Quark™ Microcontrollers Forum.
We will be looking into this issue and get back to you shortly.
Intel Customer Support
