Community
cancel
Showing results for
Search instead for
Did you mean:
Avinash_C_Intel
CDC serial and RNDIS certificate errors with intel Edison
Jump to solution
i have installed following softwares
https://downloadmirror.intel.com/25384/eng/w_iot_2015.0.031.exe Windows 64-bit Integrated Installer
http://downloadmirror.intel.com/24909/eng/IntelEdisonDriverSetup1.2.1.exe Windows Standalone Driver 1.2.1 (8.97 MB, .exe)
checked the path of c:/program files/intel edison usb drivers/MFLD_USB_driver_cert.cer and found certificates are expired on 2015/feb
and disabled the certificate check on windows 7 by typing this command and restart
bcdedit.exe -set loadoptions DDISABLE_INTEGRITY_CHECKS
bcdedit.exe -set TESTSIGNING ON
No problem with the FTDI drivers ,thanks in advance
Sergio_A_Intel
Hi @led,
I checked my certificates and my certificate screen looks exactly like yours. I hadn't noticed the certificate expired on February 2015 though. My device manager screen doesn't show CDC Serial or RNDIS in the other devices tab. I can see the USB Serial Port, the Virtual com port and the USB composite device under the ports tab.
If you are having trouble connecting, I'd suggest you to uninstall the drivers you have installed and reinstall them again. Follow https://software.intel.com/en-us/get-started-edison-windows-32-step2 IoT - Step 2: Install drivers | Intel® Developer Zone and let me know your results.
Sergio
Sergio_A_Intel
Hi @led,
Sergio
