Intel® Makers
9880 Discussions
CMOS registers
HHank
Hi everyone,
I am aware that the Edison exposes an RTC via the PMIC, x86 RTC chips usually have an extra space (114 bytes) dedicated to BIOS configuration and such.
Linux does indeed expose a file (/dev/nvram) which seems to map to CMOS registers. I have tried writting to /dev/nvram, but it seems that those bytes are reset on reboot.
Does the Edison's RTC have CMOS registers, and if it is the case, how can I use them?
Regards.
Community Manager
Hi CookieMeister,
We'll investigate to see what information is available about CMOS registers. We'll contact you as soon as we have more information.
-Sergio
HHank
Hello Sergio,
Thank you for your reply. I'm looking forward to hearing from you.
Regards.
HHank
Are there any news about this matter?
Regards.
Community Manager
Hi CookieMeister,
We've not forgotten about your case. We're still investigating and will contact you as soon as we have an update.
-Sergio
Community Manager
Hi CookieMeister,
Thank you for your patience. We'd like to know more information about your project. What is your goal specifically and what you want to do with the registers?
-Sergio
HHank
Hello Sergio,
I have used RTC volatile memory in other embedded platforms, so they could be filesystem agnostic, corruption resistant, and also a means to detect spurious reboots.
Regards.
Community Manager
Thank you for your reply. We'll look into this and reply as soon as possible.
-Sergio
Community Manager
Thank you for your patience. We've looked for information about the CMOS registers, but I'm afraid, I couldn't find anything I was able to share. I know this may not be the outcome you expected, but some features on the Edison, such as the CMOS registers are not publicly available. Please let us know if you have any other questions related to this case. We'll be waiting for your response.
-Sergio
HHank
Hello Sergio,
Let me understand. There is no information about this feature? Or the information is private and it is forbidden to share it?
Regards.
Community Manager
Thank you for your reply and giving us the opportunity to clarify this.
The information is available, but it can't be shared with end developers. We apologize for the inconvenience this may cause.
-Pablo
