What should i do?
Collected errors:
* satisfy_dependencies_for: Cannot satisfy the following dependencies for libavahi-common3:
* libc6 (>= 2.20) *
* opkg_install_cmd: Cannot install package libavahi-common3.
But i already had library:
Package libc6 (2.19-r0) installed in root is up to date.
Hi alarcondiegof,
Which image are you using? Are you using the AlexT repo to download the packages?
According to another thread, the prerequisites packages would be these ones:
opkg install http://repo.opkg.net/edison/repo/core2-32/ http://repo.opkg.net/edison/repo/core2-32/http://repo.opkg.net/edison/repo/core2-32/libavahi-common3... libavahi-common3_0.6.31-r11.1_core2-32.ipk
opkg install http://repo.opkg.net/edison/repo/core2-32/ http://repo.opkg.net/edison/repo/core2-32/http://repo.opkg.net/edison/repo/core2-32/libavahi-client3... libavahi-client3_0.6.31-r11.1_core2-32.ipk
opkg install http://repo.opkg.net/edison/repo/core2-32/ http://repo.opkg.net/edison/repo/core2-32/http://repo.opkg.net/edison/repo/core2-32/libcups2_1.7.5-r... libcups2_1.7.5-r0_core2-32.ipk
opkg install http://repo.opkg.net/edison/repo/core2-32/ http://repo.opkg.net/edison/repo/core2-32/http://repo.opkg.net/edison/repo/core2-32/libcupsimage2_1.... libcupsimage2_1.7.5-r0_core2-32.ipk
Now, once this is done you can proceed to install CUPS.
opkg install http://repo.opkg.net/edison/repo/core2-32/ http://repo.opkg.net/edison/repo/core2-32/http://repo.opkg.net/edison/repo/core2-32/cups_1.7.5-r0_co... cups_1.7.5-r0_core2-32.ipk
Did you already install the packages? You can check the whole thread following this link .
PabloM_Intel
