How to call https rest api like "https://test0001.azure-devices.net/Devices/Edison/Messages/devicebound?API-Version=2016-02-03 https://test0001.azure-devices.net/Devices//Messages/devicebound?API-Version=2016-02-03"
with Edison and Arduino sdk?
When using WiFi.h libray I can call host https://test0001.azure-devices.net/Devices/Edison/Messages/devicebound?API-Version=2016-02-03 test0001.azure-devices.net on port 443 and send a "GET instruction" but cannot get any answer from service
On the other hand, when calling REST API on http (port 80) everything is fine.
Anybody can help on that?
Marco
Hello marco1971,
Could you please check the links you posted? They don't work for me, could you please check them and post them again? Or could you please explain more deeply what you're trying to do.
-Peter.
Dear Peter,
I'm trying to send and retrieve data with Azure Iot Hub.
I can manage REST calls with other application like FIddler (for instance), sending GET commands in this way
GET https://test0001.azure-devices.net/Devices/Edison/Messages/devicebound?API-Version=2016-02-03 HTTP/1.1
Authorization: SharedAccessSignature sr=TEST0001.azure-devices.net&sig=3ftOC5UzpYAH1oTJP9Ka6%2bNRlhK3CKg4ap/XETjDpC8%3d&se=1494001566&skn=iothubowner
Host: test0001.azure-devices.net
Content-Type: application/json
With Fiddler (and other applications) this works. Now I'm trying to do the same thing inside an Arduino sketch like this one (omit wifi connection commands and other):
const char *server = "test0001.azure-devices.net";
if (client.connect(server, 443)) {
client.println("GET /Devices/Edison/Messages/devicebound?API-Version=2016-02-03 HTTP/1.1");
client.println("Authorization: SharedAccessSignature sr=TEST0001.azure-devices.net&sig=3ftOC5UzpYAH1oTJP9Ka6%2bNRlhK3CKg4ap/XETjDpC8%3d&se=1494001566&skn=iothubowner");
client.println("Host: test0001.azure-devices.net");
client.println("Content-Type: application/json");
Result is: connection to host is done, but I get no answer. When I compose other skecth like the one above for connecting on http host (port 80) everything is fine
Could you indicate what is missing to make REST calls works with https ssl?
Marco
Thanks a lot Peter.
Just a question before I flash the board: could my Issue be related with what is described in http://forum.arduino.cc/index.php?topic=17540.0 http://forum.arduino.cc/index.php?topic=17540.0 ?
Symptoms described in this arduino forum discussion are exactly the same I am experiencing. The only difference is that I am using WiFi.h library for internet connection. It seems that WiFi101.h library for Arduino IDE admit ssl connection, but this library is not available for Edison
Marco
That could indeed be affecting you. But if that was the case, I'd suggest you to change to programming on the Linux side. If you do it you'd have access to every third party Linux library, which could make things simpler when trying to interact with SSL connections.
For example you can look at this links:
http://stackoverflow.com/questions/7698488/turn-a-simple-socket-into-an-ssl-socket
http://fm4dd.com/openssl/sslconnect.htm
https://www.cs.utah.edu/~swalton/listings/articles/ssl_client.c
https://wiki.openssl.org/index.php/SSL/TLS_Client
http://www.cs.odu.edu/~cs772/fall08/lectures/ssl_programming.pdf
-Peter.
