I have in my job a Intel Compute Stick (STK1A32WFC ), and need to extend the screen to a second monitor but i can´t find how cause i only have a conector hdmi - dvi for one monitor. I need to know if someone did that. i want work like the photo.
Hi Yabyve ,
In order for you to extend the screen with the Intel® compute stick you will need to have two different outputs but the Intel® compute stick only has one output, so because of that is not possible to do extended set up.
I answered a thread with the same problem here:
/thread/92236?start=0&tstart=0 https://communities.intel.com/thread/92236?start=0&tstart=0
Ivan
Hi Yabyve ,
Ivan
Hi Ivan,
Thanks you for your answer, that confirm my investigation about this topic.
You could always go with a widi adapter and extend that way, but the response time would be off compared with the HDMI output.
I found this link: http://www.tomsguide.com/us/intel-compute-stick,review-2770.html Intel Compute Stick Review: World's Smallest Windows PC that said about the Intel Compute Stick "Short Wi-Fi range No WiDi support".
You know what? It never even occurred to me to check. I just assumed widi would be on it. I'll verify on mine tonight.
Ever say you're going to do something and then completely forget? Yep, that's me. Sorry about that. I checked on mine (first gen unit) and I don't see WiDi.
Sorry for making you wait so long!
Hi jasonNUC thanks, in this case i need a device "USB 2.0 to VGA/DVI/HDMI Adapter for Multiple Monitors".
