Intel® Makers
9868 Discussions
Can Intel Edison breakout board be powered by a Li-battery?
YLu12
Usually we provide the edison with power through the USB port. But now I want to carry the edison with me and go out.So how to provide power to the edison(with Breakout board)?
Pablo_M_Intel
Hi 朝露映曦
Yes, the Edison Breakout Board can be powered using a Lithium battery. According to the Breakout Board Hardware Guide, you should attach the lithium battery to J2. Also, if you power the board via J21, J22 (power jack which must be installed first) or J3 (USB) the breakout board will recharge the battery. The battery should provide 3.7V and at least 300mAH capacity.
You should check the Hardware Guide for some more information on this.
PabloM_Intel
Pablo_M_Intel
Hi 朝露映曦
PabloM_Intel
