Intel® Makers
9868 Discussions
Can Segger J-link Debugger be used to debug/flash D2000 boards?
ihart2
Dear all,
I have a Segger J-link which can be used well with C8051F and ARM Cortex devices. Is it possible to use it to debug/flash D2000 controller? Any idea/experience?
Michelle_C_Intel
I have not used the Segger J-Link debugger with the D2000 board but I can confirm the JTAG pin-out you suggested is correct and as OpenOCD supports it I think it should work ok.
When connecting OpenOCD you just need to specify the 'quark_d2000.cfg' file (rather than the quark_d2000_onboard.cfg)
e.g. bin\openocd.exe -f {path to J-Link config file} -f scripts\board\quark_d2000.cfg
This is the connection I have used with an Olimex Debugger . Pin 1 Connected to 3.3V on the Board and Pin 4 to Ground.
Note : Remove all sleeves from Jumpers J9, J10, J11, J15, J17
Pin 1 – (3.3V)
Pin 3 – TRST
Pin 4 – GND
Pin 5 – TDI
Pin 7 – TMS
Pint 9 – TCK
Pin 13 – TDO
ihart2
Dear Michelle,
Thanks for the reply!
I couldn't find where 'quark_d2000.cfg' should be written Also, Olimex debugger has been listed, but Segger J-link.
ihart2
This one?
Michelle_C_Intel
Have a look at the Wiki Link above -- the zip file includes the jlink.cfg. You should be able to use this with ISSM also.
Just drop it into - C:\IntelSWTools\ISSM_2016.2.094\tools\debugger\openocd\scripts\interface\ftdi
Then when Flashing the ROM choose 'Custom Configuration' and update the OpenOCD line to below ...
Similarly in the Application Debug Options set the configuration to below ..
Let me know if this works for you
ihart2
Dear Michelle,
You are fantastic! I have just managed to establish a communication between the MCU and System Studio. Now, I can downloadthe examples. I tried blinky, just working fine. Thank you very much!
However, there is one problem. I cannot upload firmware to the module. It fails during verification and returning the following message;
Open On-Chip Debugger 0.8.0-dev-g377d3f24-dirty (2017-04-11-19:24)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.sourceforge.net/doc/doxygen/bugs.html
Info : only one transport option; autoselect 'jtag'
adapter speed: 1000 kHz
trst_only separate trst_push_pull
Info : J-Link initialization started / target CPU reset initiated
Info : J-Link V9 compiled Jun 9 2017 17:27:29
Info : J-Link caps 0xb9ff7bbf
Info : J-Link hw version 92000
Info : J-Link hw type J-Link
Info : J-Link max mem block 69816
Info : J-Link configuration
Info : USB-Address: 0x0
Info : Kickstart power on JTAG-pin 19: 0xffffffff
Info : Vref = 3.356 TCK = 1 TDI = 0 TDO = 0 TMS = 0 SRST = 0 TRST = 0
Info : J-Link JTAG Interface ready
Info : clock speed 1000 kHz
Info : JTAG tap: quark_d2000.cltap tap/device found: 0x0e786013 (mfg: 0x009, part: 0xe786, ver: 0x0)
Enabling lmt core tap
Info : JTAG tap: quark_d2000.lmt enabled
adapter speed: 3 kHz
redirect to PM, tapstatus=0x08302c14
unknown break reason at 0x00180145
target state: halted
target halted due to undefined at 0x00180145 in protected mode
target halted due to debug-request at 0x0000fff0 in real mode
0xb0100014: 00000001
Setup clock
Start flash
The requested flash write overlaps the OTP DATA protected region 0x00000000 - 0x0000014f, skipping that part
The following command will allow it:
set QUARK_D2000_OTPC_DATA_WRITE_ENABLED 1
7999 bytes written at address 0x00000000
downloaded 7999 bytes in 117.621109s (0.066 KiB/s)
Start verify
It looks like I have to add command "set QUARK_D2000_OTPC_DATA_WRITE_ENABLED 1" somewhere, but, I don't know where it should be
Michelle_C_Intel
It looks like the ROM was successfully flashed and there was a timeout on the Verify. It looks like it is taking a long time to flash.
You can ignore the "set QUARK_D2000_OTPC_DATA_WRITE_ENABLED 1" message - the ROM flashing process does this automatically.
One thing you can do is try increasing the adapter speed in the C:\IntelSWTools\ISSM_2016.2.094\tools\debugger\openocd\scripts\target\quark_d2000.cfgn which should speed up the flashing.
In the clk32M function try increasing the speed from 1000khz to 4000khz for example.
# utility function to set SoC clock to 32MHz Si
proc clk32M { {jtag_khz 4000} } {
# slow speed to make sure we can write mem
adapter_khz 3
# LMT halt
irscan quark_d2000.cltap 0x70 ; drscan quark_d2000.cltap 8 0x1
# set the SoC clock to the 32 MHz Silicon one
mww 0xB0800008 0x2
mww 0xB0800038 0x7
mww 0xB0800038 0x87
# set the JTAG clock to the desired one
adapter_khz $jtag_khz
# clear halt flag and reset the SoC
irscan quark_d2000.cltap 0x70 ; drscan quark_d2000.cltap 8 0x0
reset halt
-Michelle.
ihart2
I tried, but, same. It fails during verification.
AZimi
New Contributor II
Check this: https://wiki.segger.com/Intel_Quark_processors Intel Quark processors - SEGGER - Support Wiki
