Hey there,
Hardware:
Edison Arduino bb and Mini bb with updated Yocto images
I am going through the instructions provided at 6.6.2 in the Intel Edison http://download.intel.com/support/edison/sb/edisonbluetooth_331704004.pdf bluetooth guide , page 44. The "PAN test between two Intel Edison devices" section.
I've gotten as far as item 9 on page 47, "from the first (PANU) device, connect to the second (PAN-NAP) device using the connmanctl utility:"
The commands I am using are the same as listed, except after I use:
connmanctl> services
only my wifi is listed, not the bluetooth service.
I've paired and connected the devices using bluetoothctl utility and made the 1st device trusted. I have also enabled bluetooth in connman, with it telling me that it is already enabled. I've followed all the directions up till the point where I can't see my bluetooth service. I don't understand what I am missing.
Another note is that I tried to connect anyway:
connect bluetooth_MACADDRESSOFDEVICE1_MACADDRESSOFDEVICE2
which gives me this error:
Method "Connect" with signature "" on interface "net.connman.Service" doesn't exist
I'm guessing this has something to do with the bluetooth service not showing up, but thought it may be of importance.
Hello postITnote,
That's strange, could you show me what exactly you have tried so far? I would like to see if I can replicate it with my Edison. Please make sure to separate what you did on the fisrt Edison from what you did on the second Edison.
Peter.
Sure! I just went through the process again. I may have found the problem, but it still does not make sense to me. Here are my steps and relevant log prints. Was going to make a gist, but perhaps the formatting here will actually make it more readable, so here it goes.
Chapter 4 – scanning and connecting
Have already scanned and opbatined MAC addresses of device 1 and device 2
Device 1 and 2
Rfkill unblock bluetooth
Bluetoothctl
Agent KeyboardDisplay
Default-agent
Device 1 log - all successful
root@tesla:~# rfkill unblock bluetooth
root@tesla:~# bluetoothctl
[NEW] Controller 11:22:33:44:55:77 tesla [default]
[NEW] Device 11:22:33:44:55:66 turing2
[bluetooth]# agent KeyboardDisplay
Agent registered
[bluetooth]# default-agent
Default agent request successful
Device 2 gave some success read out
Device 1 when trying to pair and connect, I get an error, but then connect and get the info from each peer, which seems to tell me it's paired and connected
[bluetooth]# pair 11:22:33:44:55:66
Attempting to pair with 11:22:33:44:55:66
Failed to pair: org.bluez.Error.AlreadyExists
[bluetooth]# connect
[bluetooth]# connect 11:22:33:44:55:66
Attempting to connect to 11:22:33:44:55:66
Failed to connect: org.bluez.Error.Failed
[CHG] Device 11:22:33:44:55:66 Connected: yes
[CHG] Device 11:22:33:44:55:66 Name: BlueZ 5.24
[CHG] Device 11:22:33:44:55:66 Alias: BlueZ 5.24
Device 2
After connecting from device 1
[bluetooth]#
[CHG] Device 11:22:33:44:55:77 Connected: yes
Device 2 and 1 (with each other's MAC addresses)
Info 11:22:33:44:55:66
Says that they are paired and connected
exit
Chapter 6.6 personal area networking
- - Edison to another edison
Downloaded test file and from bluez package and copied it to home/root on both devices
Did the enabling and connecting, shown above.
- 6.6.2 PAN test between two edison devices
Device 1 and 2
root@tesla:~# systemctl start connman
root@tesla:~# connmanctl enable bluetooth
Error bluetooth: Already enabled
root@tesla:~# hciconfig
hci0: Type: BR/EDR Bus: UART
BD Address: 11:22:33:44:55:66 ACL MTU: 1021:8 SCO MTU: 64:1
UP RUNNING PSCAN
RX bytes:3746 acl:47 sco:0 events:254 errors:0
TX bytes:217873 acl:392 sco:0 commands:47 errors:0
Device 2
./test/test-nap br0
Server for nap registered to br0
Press CTRL-C to disconnect
CTRL-C
Brctl addbr br0
Ifconfig br0 192.168.1.1
Bluetoothctl
Discoverable on
Agent DisplayOnly
Default-agent
Device 1
Bluetoothctl
Agent DisplayOnly
Default-agent
Scan on
Pair 11:22:33:44:55:66
Connect 11:22:33:44:55:66
Connection successful
Exit
Device 2
Trust 11:22:33:44:55:77
Trust succeeded
Device 1
Connmanctl
Connmanctl>services
Network name Wifi_numbers_managed_psk
Is it because there was an error when trying to initially pair? I searched for a remedy to it, but haven't succeeded eliminating after it told me it paired successfully the first time I ever enabled bluetooth. These steps are how to create a bluetooth network
Also, when I do connect and it says to ping the IP, is it the IP of the bridge? These steps are how to create a bluetooth network and not WiFi, so I'm confused as to why I would be pinging the boards IP address, I already know how to connect one board to another's network when one is in AP mode.
Thanks!
@postITnote,
I've been trying to create my own PAN; nevertheless I am facing the same issue as you. Please let me take a deeper look at this and I will try to get back to you as soon as possible.
Peter.
After some testing we were able to create a PAN on Edison, my Edison2 was missing the bluez-test packages so I downloaded them to the board. These are the steps we took:
On Edison2:
Downloaded http://www.bluez.org/release-of-bluez-5-18/ http://www.bluez.org/release-of-bluez-5-18/ to home directory
Untar file
# tar -xvf bluez-5.18.tar.xz
On both Edison boards, enable Bluetooth and start connman:
# hciconfig
On Edison2:
Go to bluez directory (untared file)
# cd bluez-5.18
Start NAP service:
# ./test/test-nap br0 &
Add bridge:
# brctl addbr br0
Set static IP:
# ifconfig br0 192.168.1.1
Launch Bluetooth* controller utility, set discoverable on and register agent:
# bluetoothctl
# discoverable on
# agent DisplayOnly
# default-agent
On Edison1:
Launch Bluetooth* controller utility, register agent, scan and pair with Edison2:
# bluetoothctl
# agent DisplayOnly
# default-agent
# scan on
# pair
# scan off
# exit
On Edison2:
# trust
On Edison1:
# connmanctl
# services
* Edison2 bluetooth_XXXX_XXXX
# connect bluetooth_XXXX_XXXX
# exit
Both Edison boards should have bnep interface:
ping 192.168.1.10
Peter.
