Intel® Makers
9873 Discussions
Can not install driver for Intel Galileo Gen 2
Community Manager
Hello guys, can you help with my problem?I using Windows 8.1 64 bit, i download driver from official site, but can not install on my PC, because i have this error, help me, please
FTinetti
Honored Contributor I
Hi atemka312,
What site & driver, specifically? Are you going to develop using Arduino IDE, Intel XDK, other?
Would you please use any translator to English for the text in the image?
Fernando.
Community Manager
Hi, i am going to develop using Arduino IDE, on the image standart error of installing driver, Where i download they you can seen on this image
FTinetti
Please send the device manager before and after you plug in your Galileo and the contents of the compressed file you donwload from Intel site.
Fernando.
Community Manager
Hi Atemka312,
Thanks for contacting us.
I would like to see as FGT said, the device manager with your Galileo plug in your PC.
Additionally, have you already installed the Arduino IDE? Also, I suggest to read this thread /thread/58619 https://communities.intel.com/thread/58619, there you can find helpful information about a similar issue.
Hope this information helps, and let us know if it works.
-Yermi
Community Manager
Hi Atemka,
I would like to know if you have any update or need more assistance.
-Yermi
VBade
I have the same problem.I see that the certificate in the .cat file just expired last month.
Trying to install the galileo gen2 on W8.1 x64 and gadget serial v2.4 device pop up in device manager.
FTinetti
Hi ValiB,
Please send the error you get (screenshot use to be the clearest way).
Fernando.
VBade
I do not have access to the PC right now, but I get the same screen like the author of this post.
I will come back with the exact error in a few hours.
Thank you.
VBade
This is the message error I get when I try to install the driver.
LE: FGT I have changed the date on my PC to match the interval in the certificate. Somehow the driver successfully installed.
What is the real solution for this problem? Can you update the .cat file (from official driver file found on the official page of Galileo Gen2) to get a new certificate which is not expired? This is a new problem because the issued certificate is expired since
11.09.2016. Thanks
FTinetti
If you did not install the Intel Galileo driver in this computer before then
a) do not use USB extension cord
b) use USB 2.0 port
c) change USB cable, usually the thicker the better
If the previous suggestions do not work, please send a screenshot of the device manager before pluging in the Intel Galilelo and after pluging in the Intel Galileo, and tell me device you select for installing the driver.
Fernando.
FTinetti
11.09.2016. Thanks
I did not know about it... thanks for reporting. It seems strange to me, since I've been installing the driver the last month (and about 2 weeks ago) and I did not have any problem...maybe it's due to local regulations... or something else... Anyway, it's good to know.
I'm sure I'm not able to do it, Intel people should reply.
Fernando.
Community Manager
Hi ValiB,
We're happy that you were able to install successfully the Intel Galileo driver; also, thank you for sharing your results in the community, it will help to other users. We'll notify to our proper team about the certificate of the .cat file has expired.
-Yermi
