Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Can servo motor be controlled without grove module?
Jump to solution
If yes, how can I program it. What should I import? Can you please paste the code. Thank you!
Tags (1)
Community Manager
Hi R@niel,
Yes, you can control servo motors using the PWM pins directly. The Arduino IDE has a couple of example codes about this. You can find them under File>Examples>Servo
Diego
FTinetti
Honored Contributor I
Hi R@niel,
You can use the example at
https://www.arduino.cc/en/Tutorial/Sweep Arduino - Sweep
and be careful: use only pwm pins for the servo motor in Galileo.
There are several useful comments about servos in Galileo at
HTH,
Fernando.
Community Manager
Hi R@niel,
Diego
