Intel® Makers
9881 Discussions
Can't Manually Compile Kernel for Intel Galileo Gen2 Board
ADas12
Hello, I am trying to cross compile a kernel for the galileo gen 2 board. I am using kernel sources 3.8.7 because they don't seem to have networking issues. I am using the following command,
make ARCH=i386 CROSS_COMPILE=i586-poky-linux- -j8
Along with a .config file I got from a working kernel I got from a debian build. I made one single change to that .config file, which was enabling swap under general setup through make menuconfig. However it doesn't seem to want to compile for me. Here is the error message through a pastebin.
http://www.lick.moe/paste/ee9841594f9eb0c2b9b8f4003f3483d6 http://www.lick.moe/paste/ee9841594f9eb0c2b9b8f4003f3483d6
Can any one suggest a solution to this problem?
Sergio_A_Intel
What other previous steps have you completed successfully before getting this error? Are you following any specific guide or BSP?
What command are you using to compile?
Sergio
Carlos_M_Intel
Hi dasreaper22,
Do you have updates with this?
Have you been able to compile the kernel?
Charlie
