Community
cancel
Showing results for
Search instead for
Did you mean:
JHugh3
Can't connect my Edison to Safari
Jump to solution
Have just started with Edison and finished the configure_edison --setup process and suggests to connect a laptop to same network and go to http://XXX.XXX.X.XX. The browser on my iMac (Safari) does not see the Edison.
If I open Terminal I can ssh root@IP address via the wireless. I have tried, iPhone, iPad browsers on the same network with no response??? Any ideas???
Thank you
KMill10
Valued Contributor II
Some versions of the Edison ship with a broken web service.
The node.js service crashes as soon as safari access it, which causes safari to think it does not exists. (Not just Safari, any web browser).
KMill10
