Intel® Makers
9868 Discussions
Can't enter bios.
БРумя
When I turn on Intel Joule, many strings of text appear and Intel logo doesn't appear, so I can't press f2 to enter the BIOS. After that Ostro OS XT appears. How can I enter the BIOS?
БРумя
I suppose fast boot mode to be enabled. And now I can't turn off it to enter the BIOS. I need some help with it.
Community Manager
Hi Boris,
Thanks for reaching out.
I would like to let you know that the Ostro image was replaced by the Ref-OS-IoT, also it is a very good practice to keep your Joule up-to-date, so I'd recommend to update the Joule's BIOS and the image to the latest version by following these guides:Note: The current base-know-configuration release is FW 1J2 + OS 1706
  • Additionally, in order to connect a keyboard, Mouse, etc., using a powered hub is recommended to ensure the platform USB output supply is not overloaded by device current draw.
Hope this information helps and let us know if you have any other question.
-Yermi A.
Community Manager
Hi Boris,
Did you try to update the Joule's BIOS and image? Do you still need help in this thread?
-Yermi A.
БРумя
I have tried to update BIOS like in this article: https://software.intel.com/en-us/flashing-the-bios-on-joule IoT. And when I tried to update BIOS through cmd it give me following message:
- Provisioning the eMMC...
- ERROR: Provisioning failed!
- 0x30003
- Device not found.
Be sure that the unit is in DnX mode and the OS has enuremated it.
Also check that the USB cable is seated completely.
- Checking for RPMB...
- ERROR: RPMB check failed!
- 0x30003
- Device not found.
- Downloading the BIOS...
- ERROR: Downloading failed!
- 0x30003
- Device not found.
So, I stopped on this step. How can I resolve this problem?
БРумя
I send you printscreen of what I have
БРумя
And also device manager shows intel DnX device in the list for a limited time. After this it dissapears.
БРумя
Okay, I have made all steps from guide you sent and now I try to turn-on Joule. And there is white light near the processor which blinks twice periodically. And there is no signal on a display. How can I start it?
Community Manager
Hi Boris,
Thanks for the information. First, I would like to let you that regarding the first error you got (screenshot), other users have reported that same issue and in those cases the issue was because they did not run the FlashUsbDriver-1.0.0.exe which is under the folder joule-firmware-2017-06-26-1J2-public\DNX\DNX-dldrcli\installer or was trying to update the BIOS in an Intel Compute Stick. Please take a look at these threads for more information:
  • /thread/115175?q=Intel%20DnX%20Driver%20Doesn%27t%20work Intel DnX driver not working properly while trying to flash the BIOS
  • /thread/105667?q=Intel%20DnX%20Driver%20Doesn%27t%20work Intel DnX Driver Doesn't work
Now, I would like to know the following:
  • Do you see an output if you power the Joule and access it via serial terminal?
  • Did you get any issues or error messages when flashed the latest BIOS and Ref-IoT-OS?
-Yermi A.
БРумя
Hello!
1. When I power up Joule I have no signal on display. What is serial terminal?
2. I have only flashed BIOS, I didn't flash Ref-IoT-OS. When I was flashing BIOS I have no error messages. All it looked fine. I send you printscreen of cmd window.
There is only white shining diode on the processor, which is blinking periodically. And there is no booting or some signal on the display.
Community Manager
Hi Boris1,
According to the picture you shared, the BIOS flashing process has not finished successfully, after the "Downloading the BIOS…" message you should see "Clearing NvStorage…" message as it is shown below:
Please try to flash the BIOS 1J2 again with the '-clear' parameter, I also highly recommend you to update the Ref-IoT-OS.
Flash.bat -clear Joule_C0-X64-Release-1J2-Public_DNX.bin
Regarding the serial terminal, you can connect a micro-usb cable to the micro-usb port (J9) on the Joule expansion board and open a putty session while you apply power to the board, refer to this guide for more details: https://software.intel.com/en-us/node/721479 Serial Terminal Communications.
I'll be waiting for your results.
-Yermi A.
Community Manager
Hi Boris1,
Did you try to flash the Joule using the "-clear" parameter as I suggested above? Do you still need help in this case?
-Yermi A.
БРумя
Hi, Yermi A!
You helped me to solve this problem, thank you a lot! And can you tell about the difference of two operating systems for Joule: Windows 10 IoT and Ubuntu Desktop 16.04 LTS? Which of these do I need to program on Joule in C++?
I have already tried to install Windows 10 IoT as well as Ubuntu Desktop. But unfortunately, under the installing Windows 10 IoT when I execute command MakeWinPEMedia /UFD C:\WinPE_amd64 G: the command line of Deployment and Imaging Tools Environment it gives an error: ERROR: Failed to format "G:"; DiskPart errorlevel -2147024809. And if I skip this error and go further I face error while booting the Windows 10 IoT on Joule: after pressing EFI USB Device in BIOS of Joule it says that booting has been failed and then the BIOS menu appers again. How can I solve this problem?
Also I've tried to install Ubuntu desktop on Joule. It was okay while making the bootable device, but when I pressed EFI USB Device it shows many strings messaging about occured error.
Could you help me with these issues?
- Boris1.
Community Manager
Hi Boris,
Great to know you were able to solve your problem.
The Joule OS supported by us is the Reference OS (Ref-IOT-OS) which can be downloaded from the site I provided you in my first reply. You can program in C++ using the Ref-IOT-OS. Unfortunately, other OSs like Ubuntu and Windows 10 IoT are not supported by us, although they are compatible with Joule, so my suggestions are limited.
After some research I found that the error you are receiving when execute the command "MakeWinPEMedia /UFD C:\WinPE_amd64 G:" can be caused because the partition of your USB flash drive is too large and the steps provided to fix that was:
  1. Clean the USB key with diskpart.
  2. Create a smaller partition. (I created a 4096MB one)
  3. Try the command again "MakeWinPEMedia /UFD C:\WinPE_amd64 X:" (change X: to the newly created partition)
Here you can find more details about the discussion: https://social.technet.microsoft.com/Forums/office/en-US/fa172b1b-48d6-4ed3-a541-f656733c1114/diskpa... DiskPart errorlevel -2147024809.
Additionally, I'd suggest you to contact Windows 10 IoT support (https://social.msdn.microsoft.com/Forums/en-US/home?forum=WindowsIoT https://social.msdn.microsoft.com/Forums/en-US/home?forum=WindowsIoT) or Ubuntu support (https://developer.ubuntu.com/core/get-started/intel-joule https://developer.ubuntu.com/core/get-started/intel-joule) in case you decided to use one of those Oss since they can provide you a more accurate answer.
Hope this information helps.
-Yermi A.
БРумя
Hi, Yermi A!
Now I try to install Ref-Iot-OS. And I've gor some qustions on it.
Do I need point file "https://download.01.org/ref-os-iot/releases/1706/5xx/full-image-intel-5xx-64.wic.xz full-image-intel-5xx-64.wic.xz" or .wic-file situated inside this .xz-file while I configure Rufus for writing image on flash-drive?
What is putty or some other terminal window display mentioned in the instruction on installing Ref-IoT-OS (on photo)?
-Boris1.
Community Manager
Hi Boris,
Let me answer your questions in order:
  1. The image file you downloaded has to be uncompressed before creating the bootable device. This means that you should use the .wic file which is compressed inside the .xz file you downloaded. Let me know if this clarifies this question.
  2. PuTTY is a terminal emulator that allows you to get access to the Joule's console to monitor the flashing process. You can download PuTTY from the following site: http://www.putty.org/. You will need the correct COM port which can be checked in the Device Manager once you connect the Joule board to the PC. This process is described with additional details in this guide, please check it and let me know if you still have questions about it: https://software.intel.com/en-us/node/721482
Have a nice day.
Yermi A.
