Intel® Makers
9881 Discussions
Can't instal IoT devkit on ubuntu 15.10
JSal
Hello all,
just yesterday I received my Intel Edison board and I was trying to install the IoT devkit but without success. The installer check the OS version and doesn't let me go any further than that since I have ubuntu 15.10. Is there any way of installing IoT in my machine?
Carlos_M_Intel
Hi jrsall92,
Are you downloading this file: https://software.intel.com/sites/landingpage/iotdk/linux-development-kit.html IoT Download - Linux* Development Kit ?
Also, could you post a screenshot of when you get the error message?
On Ubuntu 15.10, are you doing the following?
  1. Download the file
  2. Extract the files from the iotdk-ide-linux.tar.bz2
  3. Open a new Terminal Session
  4. Go to the folder where are the extracted files
  5. Run cd iotdk-ide-linux
  6. Run ./devkit-launcher
As mhahn said, which java version do you have in your machine?
Charlie
Matthias_H_Intel
what's the error message of the installer?
do you potentially miss the right Java version?
JSal
The error is that my OS is not supported.
Carlos_M_Intel
Hi jrsall92,
Charlie
JSal
The file provided in the link worked after a reset of my laptop. BTW I'm using Oracle's Java 8 (can't remember the version number).
