Intel® Makers
9882 Discussions
Can't ping or send UDP packet to host
misla5
I am trying to send UDP packets to 192.168.2.3 however when I ping the address, it hangs. I also can't send any UDP packets to that address. I tested the host using my laptop and it works as I expect it to. Is there anything Edison related that would stop me from sending UDP packets. I am connecting to a WiFi access point of a RC car if that helps any.
I pretty much can't ping my default gateway.
misla5
So I was able to fix it through my routes:
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 192.168.2.3 255.255.255.0 UG 0 0 0 wlan0
I also had to shutdown the usb0 interface.
misla5
