Intel® Makers
9881 Discussions
Can't seem to install itunes properly
Community Manager
I try to install latest version of iTunes on my Intel Compute Stick Windows 10 32-bit but it can't seem to install properly. Is it a Windows problem or due to Intel chipset in Intel Compute Stick? Please help.
Community Manager
Hello WANKS:
In regard to your inquiry, I was checking the requirements to install iTunes, and it says that it requires a Window® 64-bit version, since the stick is working with 32-bit, iTunes will not get installed, as you can confirm on the following link:
http://www.apple.com/itunes/download/ http://www.apple.com/itunes/download/
I can see here that you gave us 2 models of sticks, for the Intel® STK1A32SC, you have the option to install a 64-bit version of Windows, if the one you have is the Intel® STK1AW32SC, that one will only work with the 32-bit version.
Alberto
BHawk3
Look I read your post and I thought I have a suggestion, it may be helpful to you, few days back I faced an Error 9 issue, so I make search on how to Fix iTunes Error 9 then I found a website and fix it.
