Community
cancel
Showing results for
Search instead for
Did you mean:
SASIDHAR_S_Intel
Can the Eclipse IDE (C++) communicate to the edison board over USB rather than wifi?
Jump to solution
As I am went through the documentation for Edison, I understood that the Eclipse IDE primarily relies on the Wifi connection established by the Edison board to communicate with it. Due to some limitation if I cannot avail Wifi, is it possible to have Eclipse IDE talk to Edison board over the USB?
Sasidhar.
MGilm
Yes! I had luck with this:
https://software.intel.com/en-us/forums/topic/533839 Edison - Ethernet Over USB on Windows
-Mike
MGilm
-Mike
Carlos_M_Intel
Hi Sasidhar,
Yes you can do this by using the Ethernet over USB feature as Mike said.
On Mac
On Linux
Charlie
