Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Can we install Google's Brillo OS for IoT on the Intel Edison mini breakout board ??
Jump to solution
Google has recently introduced its all new Brillo OS specially made for IoT. Can we install it on our Edison mini breakout board right from the beginning ??
What are the possible chances for it ?
Sergio_A_Intel
It's hard to say based on the information available at this point. So far I haven't found much technical information on this OS. This OS is meant to be released in the third quarter of this year so maybe then there will be more information available. I'm not sure if it will be fully compatible with the Edison by default. You can try contacting google at https://services.google.com/fb/forms/brillogetintouch/ Get in touch – Google to get more information.
Sergio
Sergio_A_Intel
Sergio
SK22
Google told that they will release the OS in the stating of October, now we are into December, still there is no information about it. And there website also its stated that edison boad supports for the brillo. Lets wait and watch.
MRupp
I flashed my Edison sucsessfully with Brillo.
The Brillo Source Code was here: https://android.googlesource.com/brillo/manifest/ brillo/manifest - Git at Google
IGupt1
Hi Martata could you please elaborate on the process and how is it working for you?
MRupp
i wirting a detailed instruction in the next few days.
sshin12
Hello Marta,
Good Day!
It would be of great help if you explain in brief how you managed to flash the *.img brillo images to Edison?
I tried using the steps for fastboot
https://android.googlesource.com/device/intel/edison/+/master/flash_tools/brillo-flashall-edison.sh flash_tools/brillo-flashall-edison.sh - device/intel/edison - Git at Google
ut bootloader was not built from Brillo sources-boot-edison.bin.
I tried to use Intel phone flash tool, but it doesnot accept *.img files.
I am very curious to get my Edison booted with Brillo.... any help would be appreciated!
Sangi
MRupp
i wrote something
