Hello, everyone.
I am doing a project of testing FreeRTOS on board Galileo Gen 2. I have encountered an annoying problem when I tried to build the simple demo project of blinking a LED. Here is the context:
- IDE: Intel System Studio IoT Edition
- File location: FreeRTOSv9.0.0\FreeRTOS\Demo\IA32_flat_GCC_Galileo_Gen_2\Support_Files\startup.S (It's a file written in assembly language)
- compiler: MinGW GCC
- section of code where problem appeares:
gdt: .space (GDT_BYTES)
- problem: when click project->build all to build it up, it gives this message which is assigned to the code above:
.space specifies non-absolute value
Please help, thanks a lot.
The complete code is here:
/* This file is part of the FreeRTOS distributions
1 tab == 4 spaces!
/* Set to 1 to enable functionality */
# define __SHOW_KERNEL_PARAMS__ 0
/* Local definitions boot loader */
# define MULTIBOOT_SIGNATURE 0x2BADB002
# define MULTIBOOT_BOOTINFO_MMAP 0x00000040
/* Local definitions for GD table */
# define GDT_ENTRIES 8
# define GDT_ENTRY_SIZE 8
# define GDT_BYTES (GDT_ENTRIES * GDT_ENTRY_SIZE)
/* Globals and externs */
.global _mboot_hdr
.global _start
.global _restart
.extern bootsign
.extern bootinfo
.extern __text_start
.extern __text_end
.extern __data_vma
.extern __data_lma
.extern __data_start
.extern __data_end
.extern __bss_start
.extern __bss_end
.extern __stack_for_main
.global __text_start
.global __text_end
.global __data_vma
.global __data_lma
.global __data_start
.global __data_end
.global __bss_start
.global __bss_end
.extern setsegs
.extern CRT_Init
.extern kernel_load_check
.extern main
/* Local constants for multiboot section */
.set ALIGN, 1<<0 /* align loaded modules on page boundaries */
.set MEMINFO, 1<<1 /* provide memory map */
.set MAGIC, 0x1BADB002 /* 'magic number' lets bootloader find the header */
.set FLAGS, ALIGN|MEMINFO /* this is the multiboot 'flag' field */
.set CHECKSUM, -(MAGIC + FLAGS) /* checksum of above */
/* Set-up GDT */
.section .data
.align 16
.globl gdt
gdt: .space (GDT_BYTES) //this is where the problem generates
gdtr: .word (GDT_BYTES-1) /* sizeof _gdt -1 (in bytes) */
.long gdt /* global pointer to the gdt */
/* Start of application text */
.section .text.entry
/* Skip mb header */
jmp _start
.align 4
/* Multiboot header */
_mboot_hdr:
.long MAGIC /* offset = 0 */
.long FLAGS /* offset = 4 */
.long CHECKSUM /* offset = 8 */
.long _mboot_hdr /* should be header address - offset = 12 */
.long __text_start /* load address (start of text) - offset = 16 */
.long __bss_start /* load end address (end of data) - offset = 20*/
.long __bss_end /* bss end address - offset = 24*/
.long _start /* entry_addr - offset = 28*/
/* Start of executable code */
_start:
/* Store boot arguments */
movl %eax, bootsign
movl %ebx, bootinfo
/* Check to see if kernel is bootstrapped by grub */
cmpl $MULTIBOOT_SIGNATURE, %eax
jne _local_loop
testb $MULTIBOOT_BOOTINFO_MMAP, (%ebx)
je _local_loop
_restart:
/* Initialise the stack pointer */
movl $__stack_for_main, %esp
/* Reset EFLAGS. */
pushl $0
popf
/* Set up the global descriptor table */
call setsegs
lgdt gdtr
ljmp $0x8, $gdt1 /* CS descriptor 1 */
gdt1:
movl $0x10, %eax /* DS descriptor 2 */
movw %ax, %ds
movw %ax, %es
movw %ax, %fs
movw %ax, %gs
movl $0x18, %eax /* SS descriptor 3 */
movw %ax, %ss
/* Clear interrupt flag */
cli
/* Initialise platform */
call CRT_Init
/* Show kernel parameters and call main, or just call main */
# if (__SHOW_KERNEL_PARAMS__ == 1)
On successful OS load EAX should contain 0x2BADB002
EBX should contain the physical address of multiboot info structure
Push the pointers to the multiboot information structure
and the magic number on the stack and check values returned
movl bootsign, %eax
movl bootinfo, %ebx
pushl %ebx /* Multiboot information */
pushl %eax /* Magic number */
call show_kernel_parameters
# else
Call main() routine
call main
# endif
/* Should not get here, but just in case - loop forever */
cli
_local_loop:
hlt
jmp _local_loop
GLOBAL ASSEMBLY LANGUAGE ROUTINES
/* halt */
.globl halt
halt:
jmp halt
ret
/* inb */
.globl inb
inb: movl 4(%esp), %edx
xorl %eax, %eax # clr eax
inb %dx, %al
ret
/* inw */
.globl inw
inw: movl 4(%esp), %edx
inw %dx, %ax
ret
/* inl */
.globl inl
inl: movl 4(%esp), %e...
Hi John_cjh,
I think it will be difficult to get some help in this forum, since FreeRTOS is not officially supported.
I've found just a few references to FreeRTOS in threads, and none of them seem to be useful.
Fernando.
Hi, Fernando
Thank you for the response. I agree with you to that . But I still want to give it a shot anyway. Hopefully someone knows.
regards,
John_cjh
Yes, I believe you'll find a more accurate response to your FreeRTOS query if you contact FreeRTOS directly http://www.freertos.org/FreeRTOS_Support_Forum_Archive/freertos_support_forum_archive_index.html http://www.freertos.org/FreeRTOS_Support_Forum_Archive/freertos_support_forum_archive_index.html .
This link might also be helpful http://www.freertos.org/RTOS_Intel_Quark_Galileo_GCC.html http://www.freertos.org/RTOS_Intel_Quark_Galileo_GCC.html
-Sergio
Hi,@Sergio
Thank you for your response. Actually, I have been working on the websites you mentioned before I came here for help. Yet I can't find information involving this problem. It seems like no one else has met this bug. I will try to contact engineers of FreeRTOS for further information.
regards,
John
Hi John_cjh,
Let us know what you find out after contacting FreeRTOS. Feel free to share your findings with the community.
-Sergio
" .space specifies non-absolute value" means that need to provide an absolute value, not a calculated value as in your case.
Try the following:
gdt: .space 64
Also note that:
.space size , fill
This directive emits size bytes, each of value fill. Both size and fill are absolute expressions. If the comma and fill are omitted, fill is assumed to be zero. This is the same as `.skip'.
BR,
xbolshe
Problem solved.
It turns out that the environment of windows hasn't been correctly configured.
The instructions of building up GCC compiler is quiet vague in http://www.freertos.org/RTOS_Intel_Quark_Galileo_GCC.html FreeRTOS running on the Intel Galileo (x86/IA32 Quark SoC X1000) .
Here is what I did:
->Install cross compiler mingw-get-setup.
-Download MinGW from sourrceforge.net.
-Install it by double clicking .exe. It is recommended to install under C:\ directory.
-Follow the instructions given and in the Basic Serup menu, install tools: mingw32-
base, mingw32-gcc-g++,mingw32-gcc-objc,msys-base.
-Finish the installation. Add in paths of windows environment the following paths:
C:nMinGWnbin;
C:nMinGWnmsysn1.0nbin;
->Install x86 GCC elf compiler. Download the pre-built i686-elf-gcc GCC tool chain refer-
enced from the osdev.org website. Add the bin directory in your path:
...\ghost-i686-elf-tools-win32\ghost-i686-elf-tools\bin;
-In Eclipse, go to project properties->C/C++ Builder->Tool Chain Editor", use "Cross GCC" and "CDT Internal Builder".
