Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Cannot connect Galileo Gen. 1 to PC, power LED blinks
Jump to solution
Hello everyone!
I just got Intel Galileo Gen. 1 with 5V/2A power supply and I want to connect it to my PC with Windows 7, with no luck. When I plug in the power cable, Galileo's power LED blinks approx. once a second. When I connect the USB cable, it is on all the time, but Galileo is not recognized in Windows. Here is the http://sendvid.com/suyecn35 video I recorded.
Could you help me?
asss
Valued Contributor II
because ON LED and Ethernet LED are flashing simultaneously, there is a problem with a power supply.
What kind of problem is a good question. It may be a problem with a power adapter.
It is better to find another 5V power adapter and check.
BR,
xbolshe
asss
BR,
xbolshe
Pedro_M_Intel
Hello rugby,
I agree with xbolshe, but if you want to make sure the issue is related to the power supply you could measure its output with a voltmeter to check if its in fact 5v.
Peter.
FTinetti
Honored Contributor I
I agree with previous posts, the most likely problem is the power supply, are you using the one included with the Galileo card? (most of power supply problems I've seen are related to using a "similar" one, not the original). Make sure V and A are the required ones).
HTH,
Fernando.
Community Manager
No, I am using an unofficial power supply, which claims to be 2A/5V. Thanks for the replies, I will try with another one.
