Community
cancel
Showing results for
Search instead for
Did you mean:
CCHIT1
Cannot find module '/home/root/blink.js'
Jump to solution
I am pretty new to the Edison board, what I have achieved so far is as below :
> Connected SSH
> Built one project [node.js] and uploaded to edison board
> I am not able to run the project using command Node main.js
> It throws error
root@Alpha:~# node main.js
module.js:327
throw err;
Error: Cannot find module '/home/root/main.js'
at Function.Module._resolveFilename (module.js:325:15)
at Function.Module._load (module.js:276:25)
at Function.Module.runMain (module.js:441:10)
at startup (node.js:139:18)
at node.js:968:3
CCHIT1
SOLVED : By default the package is uploaded to node_app_slot folder hence to resolve this issue proceed with all commands in node_app_slot over the shell of the board while using node to execute programs.
CCHIT1
