Intel® Makers
9868 Discussions
Cant build examples for D2000 - Wont build app_entry.o
mo_bri
I cant build the examples I get this error (and app_entry.o doesn't get built but main.o does)
14:46:17 **** Incremental Build of configuration Release for project Ex1 ****
make
APP_NAME = Ex1
SOC = quark_d2000
TARGET = x86
APP_DIR = .
BUILD = release
CSTD = c99
VERSION = '1.1.0'
MARCUS !! Version defined
MARCUS 2 !!
MARCUS PRE prepre sys.mk !!
MARCUS PRE sys.mk !!
MARCUS sys.mk !!
MARCUS quark.mk !!
MARCUS About to link!!
make -C ./bsp/drivers SOC=quark_d2000 TARGET=x86 BUILD=release V=0 CSTD=c99
BUILD = release
CSTD = c99
VERSION = '1.1.0'
MARCUS 2 !!
MARCUS drivers.mk !!
MARCUS quark.mk !!
make[1]: Entering directory `C:/IntelSWTools/ISSM_2016.1.067/workspace/Ex1/bsp/drivers'
make[1]: Leaving directory `C:/IntelSWTools/ISSM_2016.1.067/workspace/Ex1/bsp/drivers'
CC release/quark_d2000/x86/obj/main.o
/usr/bin/sh: -c: line 0: unexpected EOF while looking for matching `"'
/usr/bin/sh: -c: line 1: syntax error: unexpected end of file
make: *** [release/quark_d2000/x86/obj/"."/app_entry.o] Error 258
14:46:47 Build Finished (took 29s.591ms)
Sergio_A_Intel
Are you still running the tests on Windows 10? Could you post screenshots of the steps you took that led you to this error? We tested the Hello World on Windows 8.1 and didn't see this issue.
-Sergio
mo_bri
Yes I'm running on windows 10. Are you aware that permissions have changed significantly in Windows 10 ? This OS is much stricter about default ownership of resources ie folders. So I think if you run on windows 10 (its free to upgrade) you will see similar issues.
The steps Im taking are really very straight forward.
1. Clean install of ISS
2. Run ISS via iss_mcu_ide_eclipse-launcher.bat (either double click from GUI or run via cmd.exe same results, even tried Run as admin from GUI context menu (right click) same results
3. When elcipse starts - select recommended - default workspace folder (C:\IntelSWTools\ISSM_2016.1.067\workspace)
4. From start page in eclispe - Click on File -> New -> Intel project for Microcontrollers
5. Wizard starts -> Select Intel Quark D2000 Dev Board -> Next
6. Select Intel QMSI (1.1) -> Next
7. Left defaults - Onboard USB -> Next
8. Name of project dave - select Hello World example - Finish
9. I dont change any files at all, and see that the project is displayed OK
10. Click the hammer icon on the tool bar - build debug config - fails to build with 2 errors
Here is the build output (note that release config is the same)
There build output from the console view (with errors)...
13:49:05 **** Build of configuration Debug for project dave ****
make
APP_NAME = dave
SOC = quark_d2000
TARGET = x86
APP_DIR = .
BUILD = debug
CSTD = c99
VERSION = '1.1.0'
make -C ./bsp/drivers SOC=quark_d2000 TARGET=x86 BUILD=debug V=0 CSTD=c99
BUILD = debug
CSTD = c99
VERSION = '1.1.0'
make[1]: Entering directory `C:/IntelSWTools/ISSM_2016.1.067/workspace/dave/bsp/drivers'
CC ../drivers/debug/quark_d2000/x86/obj/clk.o
Assembler messages:
Fatal error: can't create ../drivers/debug/quark_d2000/x86/obj/clk.o: No such file or directory
make[1]: *** [../drivers/debug/quark_d2000/x86/obj/clk.o] Error 1
make: *** [libqmsi] Error 2
make[1]: Leaving directory `C:/IntelSWTools/ISSM_2016.1.067/workspace/dave/bsp/drivers'
13:49:24 Build Finished (took 18s.675ms)
Can't get more detailed than that ! You are aware that the errors are caused by make not having permissions to use "mkdir" aren't you ? I keep mentioning this, Windows 10 permissions will cause this. These errors go away when I manually create the folders that make can not generate. Then it goes to the errors mentioned above (top of this thread)
Marcus
mo_bri
I even tried to create a workspace under my own user folder space - ie C:\Users\mobrien\newworkspace\ and I still got the same problem.
mo_bri
I then tried to install the ISS in my own area C:\Users\mobrien\Desktop\ISS then ran ISS and same errors. (even running this new install as admin).
mo_bri
OK I have a fix for you, change all your .mk files from this type of statement
$(call mkdir -p, $(DRV_DIR)/$(BUILD)/$(SOC)/$(TARGET)/$(OBJ))
To this one (take off call and the coma)
mkdir -p $(DRV_DIR)/$(BUILD)/$(SOC)/$(TARGET)/$(OBJ)
I changed all the .mk files
This way the "call" doesn't change the user. This works up to the point of...
BUT I STILL END up with this error
14:40:20 **** Incremental Build of configuration Debug for project Hello_World ****
make
APP_NAME = Hello_World
SOC = quark_d2000
TARGET = x86
APP_DIR = .
BUILD = debug
CSTD = c99
VERSION = '1.1.0'
MARCUS Hello about to make the folders - mkdir
MARCUS DONE IT
BUILD = debug
CSTD = c99
VERSION = '1.1.0'
MARCUS in bsp drivers now
MARCUS in bsp drivers about to mkdirs
make[1]: Entering directory `C:/Users/mobrien/Desktop/ISS/ISSM_2016.1.067/workspace/Hello_World/bsp/drivers'
mkdir -p ../build/debug/quark_d2000/x86/libqmsi/include
make[1]: Leaving directory `C:/Users/mobrien/Desktop/ISS/ISSM_2016.1.067/workspace/Hello_World/bsp/drivers'
mkdir -p ./debug/quark_d2000/x86/obj
CC debug/quark_d2000/x86/obj/main.o
mkdir -p ./debug/quark_d2000/x86/obj/"."
make: *** [debug/quark_d2000/x86/obj/"."/app_entry.o] Error 258
14:40:43 Build Finished (took 23s.137ms)
Sergio_A_Intel
Thank you for providing these steps. We've have only tested this scenario using Windows 8.1, we'll run the test on Windows 10 and report our results back to you. Thank you for your patience.
-Sergio
MHibb
marcuso,
I use ISSM 2016 Update 1 on Windows 10 on my home PC.
I do not get the same issues as you; the install and sample application build process is clean.
I just uninstalled & re-installed again, allowing all the default options, and building the sample hello world works fine.
I would like to help solve your issues.
A few question that might help the team here understand why it is not working for you:
1) How is your Windows 10 environment installed; is your user account locked down differently to a standard Windows 10 install account?
2) Is there perhaps anything unusual about your system that you might like to mention? Do you have a unusual disk partition, network drive, command shell, account settings?
3) What virus scanning / malware protection tool do you have installed?
4) Do you have Eclipse already installed, such as with Android Studio?
Sometimes having other development tools installed can mess with the particular version of make.exe used, but I have loads of FPGA and MCU development tools installed before I started, and they didn't interfere with my setup.
Mike
Michelle_C_Intel
Apologies for the delay getting back on this issue - If you are still having issues can you please try this workaround.
Update the PATH settings at the end of the C:/IntelSWTools/ISSM_2016.1.067/issm_env.bat to :
:: Extend PATH with ISSM tools
set PATH=C:\WINDOWS\System32\Wbem
set PATH=%ISSM_UTILS_ROOT%;%ISSM_TOOLCHAIN_BIN%/;%ISSM_TOOLCHAIN_UTILS%;%ISSM_TOOLS_ROOT%/python;%PATH%
Resstart ISSM and try building your project.
-- Michelle.
Sergio_A_Intel
Hi Marcus,
Do you still need assistance with this thread?
-Sergio
mo_bri
Thanks to MichelleC_Intel this is totally fixed. I can now create new projects based on any of the examples (LED/compass) and they build/link and execute. Thanks for helping out. All of my problems are resolved ! Except of course how to use simple i2c !
