Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
Capactive sensor pad that is compatible with Arduino/Galileo
Hi guys,
Would anybody know of a capactive sensor pad that is compatible with Arduino/Galileo. I want to use the pad as a touch "screen" where I can assign numbers/letters to different parts (maybe x-y corrdinates) of the pad and get some basic input (ABC and 1,2,3) etc.
Appreciate any input
Tags (1)
Highlighted
Re: Capactive sensor pad that is compatible with Arduino/Galileo
Hi conor100
Most of the capacitive sensors, shields and keypads I've seen use I2C Communication, this library isn't supported yet but I know that the I2C communication is possible in Galileo, I think they might work unless they have an AVR dependency to make sure look at the .cpp and .h files of the library that uses the shield or keypad. If I get one and works I'd let you know.
JPMontero_Intel
